Username Post: Computer Memory        (Topic#351114)
go_hercules
Reg: 10-27-16
05-14-18 08:43 PM - Post#2733996
1990 C1500
I am going to change my blower motor out in a couple of days. I will need to disconnect and remove the computer for access. I have never disconnected the computer on this truck so I had a couple of questions before diving in.
(1) does disconnecting the computer mean that everything will have to be "relearned" after hooking it back up (throttle position sensor for example) or does it store this information for some period of time?
(2) I read somewhere that if the computer is left disconnected for too long, it would have to be "reflashed" whatever that means. How long is safe to leave it disconnected? If I get the thing apart and have the wrong blower or whatever, it could be down for a few days or more.
(3) When I'm done and reconnect it, is there anything special I have to do, like any sort of reboot or what-not?
Thanks very much.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
05-15-18 03:52 AM - Post#2734003
    In response to go_hercules
Its been a long time since I replaced the blower motor on one of those but im sure I never took the ecm out to do it. I do recall taking the bolt out of the bottom of the dash to make it easier to remove it.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
05-15-18 05:56 AM - Post#2734009
    In response to junkman104
The computer will be fine. You really don’t have to disconnect it.
It is installed on a tray. There are two sockets on the right side of the tray that receive two pins that are attached to the ECM box. The left side is held in place with two spring clips.
Slide it to the left to release it from the tray and then You can maneuver it a bit to spin it and have it sit out if the way so you can see to remove the screw(s). 7mm
The computer and PROM never lose their memory. The only thing lost is any trouble codes that may have been set.
There are no special reflash requirements.
Greg
'00 Explorer XLT 4.0 V6 Auto
go_hercules
Reg: 10-27-16
05-15-18 09:19 AM - Post#2734029
    In response to CowboyTrukr
If I am able to set the computer aside, do you think I will have to remove the tray it sits on to get the blower rubber cover off? I watched a video and the guy took the computer and tray completely out.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-15-18 07:09 PM - Post#2734061
I just did mine recently.
To be done properly I had to remove my ecm.
Same year as yours.
Let me see if I can find it.
was recently.
Read my topic BLOWER MOTOR REPLACEMENT.
I bumped it up so you will easily see it.
I hope it helps you
Old School GM fan FOREVER
Edited by rockfangd on 05-15-18 07:12 PM. Reason for edit: No reason given.
go_hercules
Reg: 10-27-16
05-15-18 07:38 PM - Post#2734063
    In response to rockfangd
Thanks a lot for that. I had not seen that thread. Your last post in that thread said pictures coming????
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-15-18 09:03 PM - Post#2734074
Yes.
I have a very hectic working schedule so time is not something I have much of.
If I get home early enough tomorrow night I will try to post a pic or 2
go_hercules
Reg: 10-27-16
05-16-18 03:00 PM - Post#2734118
Well I tackled this job today and it wasn't too terribly bad. Without the instructions from Rockfangd, it would have been much, much worse. The tip about prying the pivot bracket out and back was the lifesaver. That did the trick. It did take quite a bit of force to pry that bracket out, more than I was expecting. And like you guys said, the computer worked fine after plugging it back in. Thanks.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-16-18 06:25 PM - Post#2734138
Great to hear. I have done enough of these, dont like to take shortcuts,
But if I was confident in doing it on mine I would recommend it.
Execution time: 0.303 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:52 AM
