Username Post: Steering shaft sticks out too far!        (Topic#351111)
BG
Reg: 09-12-07
05-14-18 06:17 PM - Post#2733982
On my 57 Chevy wagon with stock steering box the shaft sticks out too far! Even with both brackets loose and the column slid forward there is still 1/2” over the 1.015 from the surface of the turn signal housing to the top edge of the steering shaft spline! The 1.015 is from the assembly manual if I understand it correctly. How do I fix it? I could shorten the shaft or put 1/2” spacers begins the saddle type bracket (instrument panel attaching bracket). But before I do anything else what should I check? Thanks
05-15-18 07:13 AM - Post#2734017
    In response to BG
What is restricting the column from going any farther? Is it the slots in the dash mounting bracket? Link to dash bracket. Is the body located correctly on the frame? I would NOT cut the shaft. You could elongate the slots in the bracket or shim under the bracket.
BG
Reg: 09-12-07
05-15-18 07:52 AM - Post#2734020
    In response to acardon
When sliding it up to close the gap the bolts hit the end of the slot! I shimmed the bracket 1/2” and that will take care of the gap. Thanks
05-15-18 07:57 AM - Post#2734021
    In response to BG
Did you try the steering wheel? or are you going just by the measurement? It could be a missprint, I have always used a small gap between the wheel and housing to adjust. It's hard to believe it could be that far off if the body is located.
Edited by acardon on 05-15-18 07:58 AM. Reason for edit: No reason given.
Execution time: 0.503 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:47 AM
