Username Post: 62 window trim        (Topic#351103)
fander
fander
Loc: Hot Springs South Dakota
Reg: 04-28-12
05-14-18 12:36 PM - Post#2733955
Where does the short piece go? Thanks - Glen
Attachment: windowt.jpg (212.95 KB) 3 View(s)
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
05-14-18 02:06 PM - Post#2733962
    In response to fander
Those pieces are for the door panels. I assume they came in a set with new rubber reveal molding sweeps for the top of the doors and rear 1/4's.
Paul
Any new interior door panel and Rear 1/4 trim panel assembled sets will have those pieces stapled to the new door panels.
As I noted above When you buy new rubber reveal molding wisker strips for the stainless on the top of the door panels & 1/4's you get the rubber for the stainless on the doors and tops of the rear 1/4's "and you also get" the wisker pieces for the door panels & rear 1/4 panels.
If you bought new door panels they should come with the ones in your picture(On my cars I buy the whole set and have the assembled door panels "done by Cars or Ciadella use those pieces on my new door panels so I do not have to try to staple them to the panels like the factory did.
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Website http://paulstensland.com/
[image]http://chevytalk.org/sm/26453.jpg[/ima
junky
Loc: Northeast CT
Reg: 06-27-10
05-14-18 09:52 PM - Post#2733998
    In response to pvs409
I called Cars to get a price on door panels for my 1962 BelAir wagon, and they told me that I would have to transfer the emblems from my old door panels to the new panels, and put the "fuzzies" on myself. I decided when the time comes to order them, I will get them made from Ciadella. I was going to ask the question "who does a better job", however, after speaking to both, it was clear that Cars doesn't do the "complete" job, and Ciadella does the whole job with all new parts. The only thing that I will have to do is install them.
pvs409
pvs409
Reg: 01-10-05
05-15-18 07:02 AM - Post#2734012
I am referring to the long chrome beaded piece with a hard plastic backing and the fuzzy covering (in your picture ) and that they are for the front door panels and rear 1/4 panels.
The short piece in his hand, if it does not have a chrome bead on it is for the front door rear track - that has those small fuzzy pieces riveted to the vertical track, to rub/touch against the chrome window frame as part of the rear track function when it’s adjusted correctly ( I can post some pictures )
Paul
Execution time: 0.29 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:03 AM
