Username Post: Cleaning leaves from Cowl vent        (Topic#351086)
1belair1954
Reg: 12-24-12
05-12-18 10:55 PM - Post#2733835
Hi everyone I have a 1960 El camino I noticed the cowl vent/grill (sits below the windscreen)has dead leaves underneath it. Is there any way I can get a vacuum hose into this area without removing the grille?
Also I removed about a wheel barrow load (no joke)of dead leaves from the inside of the front fenders and where the bottom door hinge pocket bolts into. Trying to workout how all these passages are connected so I can clean them out.
this car must have been parked under a tree for a very long time.
Thanks in advance
Edited by 1belair1954 on 05-12-18 10:55 PM. Reason for edit: No reason given.
59cheviac
Loc: the sunshine state
Reg: 10-31-03
05-13-18 06:59 AM - Post#2733848
    In response to 1belair1954
You can remove the interior kick panel vents and go at the cowl ventilation system from that direction, but seems like it would be much easier to just remove the top grille and work from there.
1belair1954
Reg: 12-24-12
05-13-18 10:27 PM - Post#2733919
    In response to 59cheviac
Thanks Cheviac I have the kick panels removed already see If I can get a hose up there Thanks again
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
05-14-18 07:22 AM - Post#2733935
If you decide to take the cowl vent off, make sure you get some PB Blaster under the windshield wiper pivot arm before you try to get the wiper arms off.
I mentioned PB Blaster because it is the very best penetrant I've ever used.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
Execution time: 0.269 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:05 AM
