Username Post: Dry or sealed?        (Topic#351052)
Sethmark
Loc: Statesboro, GA
Reg: 05-04-16
05-10-18 11:22 AM - Post#2733607
I like you guys. Little more gray in the beard and more experienced than most forums. So today I ask.... I’ve converted to a cast valve cover since the 60 year old original needed diapers.
High tack or dry on that cork? How tight on the acorns?
2blu52
2blu52
Reg: 03-12-02
05-10-18 11:26 AM - Post#2733608
    In response to Sethmark
As I recall, no sealer is recommended in the manual, however given the nature of stuff to warp, bend, chip and have other failures I use a very thin coat of silicon on both the block and the top of the gasket. Others say none the block. A personal choice. At least some one appreciates my 84 year old grey hair and beard.
THOMAS JEFFERSON
Sethmark
Loc: Statesboro, GA
Reg: 05-04-16
05-10-18 11:35 AM - Post#2733610
    In response to 2blu52
I do. Too much good info goes to waste if I don’t ask.
Edited by Sethmark on 05-10-18 12:08 PM. Reason for edit: No reason given.
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
05-10-18 02:47 PM - Post#2733630
ON CORK,I WOULD USE THIS,HAS MORE "GRIP".EVENTUALLY I GOTA DO A OIL PAN & GASKET ON THE FURD.I GOT THE CORK GASKET.WE USE THAT THAT IN WORK
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
DanD1950
DanD1950
Loc: London Ont. Canada
Reg: 10-16-11
05-11-18 04:23 AM - Post#2733659
    In response to TAT_2
Throw the cork gasket in the garbage and use silicone only.
I also agree with TAT_2 the ultra black is a very good silicone; but I use its big brother, the right stuff black.
https://youtu.be/cKEFXOnWve4
Dan.
50 Styleline Deluxe, 2 Door Sedan, Was a 216cu", Three Speed Manual. She now has a 4.8Lt V8 LR4 injected engine, 4L60E 4 speed automatic, 10 bolt diff 342 gear with an Eaton C80 Locker
Edited by DanD1950 on 05-11-18 04:27 AM. Reason for edit: No reason given.
2blu52
2blu52
Reg: 03-12-02
05-11-18 05:21 AM - Post#2733660
One more remark, the Acorns can be over tightened,I just run them down until they are snug not bottomed out, if no leaks then leave them alone. I like cork because of the rebound effect which leaves room for future tightening. To much wrench can distort the cover.
THOMAS JEFFERSON
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
05-11-18 07:40 AM - Post#2733680
No sealer was used by the factory or professional mechanics.
Sethmark
Loc: Statesboro, GA
Reg: 05-04-16
05-11-18 09:26 AM - Post#2733690
    In response to Gene_Schneider
Factory valve cover leaks a little. So I spent big $$$ on a cast cover. It leaks a LOT. 3 gaskets later it's still leaking. A lot.
Tried 3 different ones and it just will not stop.
Back to factory.
DanD1950
DanD1950
Reg: 10-16-11
05-12-18 10:27 AM - Post#2733779
Back to factory.
Like I said in an earlier post, in this thread.
Get the "RIGHT STUFF" form Permatex. If it is applied properly (Clean oil free surfaces) there's no way it'll leak. Oh Yeah throw the gasket out; silicone and cork gasket, do not like each-other.
The silicone will distort the cork and sure as poopoo it'll leak.
Usually a 1/8" bead of silicone is all that's required; but if there's concern of warpage of the cast cover. Lay
50hotrod
50hotrod
Reg: 07-25-11
05-12-18 09:08 PM - Post#2733830
    In response to DanD1950
Back when, we always used High tack to glue the cork gaskets to the valve covers. It stopped them from sliding out after time and if need be, you could remove the cover and reinstall with the same gasket. Re-tighten after a few heat cycles when new.
People done gone put their Bible's away
Edited by 50hotrod on 05-12-18 09:09 PM. Reason for edit: No reason given.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
05-16-18 03:29 PM - Post#2734120
Hi Sethmark, Did you put the cast rocker cover on a flat surface. If its a flash copy (Aftermarket made from an old one.) it could well be twisted.
What quality material you cast them from and what process you use matters for true shaped products.
A flat one should seal better than the flexible stocker.
Cheers kiwi
Sethmark
Loc: Statesboro, GA
Reg: 05-04-16
05-22-18 01:26 PM - Post#2734639
    In response to Bel Air kiwi
I did and it is not square.... and the company is ignoring me.
Execution time: 0.316 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:54 AM
