Username Post: removal of propeller shaft        (Topic#351043)
VanLife
Reg: 03-20-18
05-09-18 05:15 PM - Post#2733549
1987 GMC vandura 2500 v6 4.3l split driveshaft
Wondering how to get it off, so I can move the trans. back to access flex plate for inspection and possible repair.
It does not "show" how to do it in the service manual.
Mine is the one where the front segment is the part where it slips over the top of the driveshaft going to the back. where you have the bushing holder? right after the short piece. If this can be removed it allows the trans to move back about 1ft straight back before hitting the head of the rear segment of driveshaft.
I don't know how to disengage it without taking the entire drive train apart. I believe there is a way to get it disconnected without having to remove the bushing holder that raps around the long driveshaft segment going to back.
My transmission is the one with 2 support bars bolted to the front bottom protective cover protecting the flex plate and starter head. The support bars also goes up and bolts to the engine side mount bracket, to lock the trans to the engine from the bottom.
I would be doing this alone on the ground.
I believe the flex plate is broke or a bearing internal on the back end is bad.
Due to torsion wheel being shot to hell and the bolt holding it in place was not tight when removing it. Also the vibration changes based on idle speed acceleration and other factors.
I can not afford to get gouged ~300$ by a mechanic to replace a $40 part if it is cracked or damaged.
I rather pay the $40flex plate and $69(floor rolling jack)
I have not done this and would be doing it alone I intended to park my van facing down a slope to make it easier to put the trans back in with assistance from gravity.
Edited by VanLife on 05-09-18 05:22 PM. Reason for edit: No reason given.
VanLife
Reg: 03-20-18
05-09-18 05:23 PM - Post#2733553
    In response to VanLife
do I have to worry about the torque converter sliding off the end of trans??
VanLife
Reg: 03-20-18
05-10-18 04:28 PM - Post#2733642
correction I do have a 2 ft section driveshaft connected directly to back of trans. the disconnect yoke is after the hanger bushing.
WHAT a PAIN just to check flex plate under the bell house cover. Tried, Can't get the cover off without moving coolant lines and exhaust pipes since mine are welded from muffler to the exhaust manifold. and there is a portion of the cover that raps around the starter that won't clear due to coolant lines location.
Senior Chevytalk Moderator
05-13-18 11:32 AM - Post#2733873
Ouch!! I've never worked on a dual shaft van. I'm not familiar with them. I've worked on trucks with dual shafts. If you can remove the cover plate, use a large pry bar or screw drive to turn over the flexplate. A good small mirror and light will help inspect the flex plate. Missing or broken teeth will throw off balance.
Execution time: 0.381 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:02 PM
