Username Post: Front seat removal        (Topic#351020)
falotz2
Reg: 11-01-16
05-08-18 07:16 AM - Post#2733376
Alright all. Since you all are a wealth of info and I just completed my complete drivetrain overhaul and new SBC swap its time to move on to the interior. I am doing the door panels myself (nothing special just some new mexican blanket stuff) I need to know where the bolts that hold the front seat are to remove it? Any pointers, tips or pics that you guys could provide would be helpful. Thanks in advance all
2blu52
2blu52
Reg: 03-12-02
05-08-18 07:51 AM - Post#2733383
    In response to falotz2
The bolts are in the corners of the seat and are kind of a pain in the you know what. Coming out is fine going back in is troublesome as the seat frame work kind of gets in the way of inserting the bolts. When re installing I would place the bolts in the holes in the seat frame first.
THOMAS JEFFERSON
52BA
52BA
Loc: Newberg, Oregon
Reg: 04-12-06
05-08-18 08:04 AM - Post#2733387
    In response to 2blu52
I put the seat bolts in from under the floor then set the seat in over the studs and secured it with nuts and washers.
Made a sometimes very difficult job easy.
Gary
2blu52
2blu52
Reg: 03-12-02
05-08-18 09:01 AM - Post#2733396
    In response to 52BA
Gary
Another brilliant idea shared with the less than knowledgeable.
THOMAS JEFFERSON
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
05-08-18 09:20 AM - Post#2733398
I don't know what year you are working on, but the seat in my '54 was removed by removing the rear bolts and sliding the seat back out of the front seat retainers. The rear bolts were easy to get to by adjusting the seat all the way forward.
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
Larry E
Larry E
Loc: Los Angeles
Reg: 09-15-16
05-08-18 01:30 PM - Post#2733416
    In response to Rustchips
Not sure what year your car is but I removed my seat a few times and it was much easier to take out when I removed the door stop bracket. But be careful not to open it too wide or you will dent the molding outside. 50 Styline 4 door.
05-08-18 06:15 PM - Post#2733447
On my 48 when I took the front seat out to do the rewire, I put studs in the holes before I put the seat back in. It makes it a lot easier. I have had the seat out 2 or 3 times since then. Don't know if the 49-54's are the same.
52BA
52BA
Reg: 04-12-06
05-09-18 06:43 AM - Post#2733488
1952 Belair.
Gary
falotz2
Reg: 11-01-16
05-09-18 07:15 AM - Post#2733493
Thanks all sorry its a 1954 I will give it a try hopefully its not too bad.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
05-09-18 10:33 AM - Post#2733508
If it's a 2-door and you are going to be doing the seats anyway, then take the seat backs off first. The front seat weighs a ton, and about 1/2 of that is in the backs.
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
falotz2
Reg: 11-01-16
05-09-18 10:47 AM - Post#2733509
    In response to dsacton
Just doing carpet and door panels. The seats are practically new.
Dave in VA
Dave in VA
Loc: SW Virginia, USA
Reg: 03-11-18
05-09-18 11:31 AM - Post#2733519
Is it easy to remove the seat backs? '50 2dr
"Knowledge is Good" -- Emil Faber
U S Navy MM2 1970-75 USS Canisteo AO-99, USS Miller DE-1091 (The Champagne of Ships)
1950 Styleline Deluxe 2dr, mostly stock, driver quality...new to me 3/18
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
05-09-18 12:08 PM - Post#2733524
    In response to Dave in VA
Yes, it is quite easy. I have pictures from my '54 removal if you are interested.
Scott Acton
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
05-09-18 12:29 PM - Post#2733526
Are you sure, you have to remove the seats to replace the carpet? Other than the back seat cushion.
Cleon
1928 Chevy Coupe
1970 El Camino
Dave in VA
Dave in VA
Reg: 03-11-18
05-09-18 04:20 PM - Post#2733545
Yes, I'd like to see those pics
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
05-09-18 05:19 PM - Post#2733550
First, you need to remove the clamshell which is held on with 3 screws.
Next, you remove the metal cover from the center, which is held on with a single screw.
Finally, you remove the C-ring from the outside. Tip the back forward and it will slip right out.
Good luck!
Attachment: moulding.jpg (78.19 KB) 4 View(s)
Clamshell
Attachment: Center.jpg (89.46 KB) 2 View(s)
Center metal cover
Attachment: left.jpg (62.25 KB) 4 View(s)
Driver's side
Scott Acton
falotz2
Reg: 11-01-16
05-10-18 09:11 AM - Post#2733597
Yes if you could send me pictures please. falotz2@hotmail.com Thanks
Edited by falotz2 on 05-10-18 09:12 AM. Reason for edit: No reason given.
Dave in VA
Dave in VA
Reg: 03-11-18
05-10-18 11:59 AM - Post#2733615
Thank you so much This will be a help in the future.
Edited by Dave in VA on 05-10-18 01:24 PM. Reason for edit: No reason given.
Execution time: 0.311 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:55 AM
