Username Post: 67 impala gauge cluster harness question        (Topic#351004)
Jordie
Loc: Australia
Reg: 10-02-13
05-07-18 01:02 AM - Post#2733259
Hi all,
I just bought a gauge cluster with tach for my Australian built 67 impala. (For those who don’t know I’m getting the American dash converted to suit a RHD impala. The Australian built 67 imaplas had the 65-66 American dash). I’m just wondering will I need the correct harness for the cluster or can I use my current harness (from the 65-66 American style dash, yes all the bulbs still work correctly etc) and just connect the sending wires (fuel, ampage, oil and temp) to the prongs on the back of the cluster? Would this still work as long as it’s earthed? Or does anyone know where to find a harness for the cluster?
Cheers
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
05-10-18 09:00 AM - Post#2733594
    In response to Jordie
No you can't use your original harness. Ammerican Auto Wire is a Chevy Talk sponsor. They carry the correct harness.
Edited by BigDogSS on 05-10-18 09:01 AM. Reason for edit: No reason given.
Jordie
Loc: Australia
Reg: 10-02-13
05-11-18 05:31 PM - Post#2733732
    In response to BigDogSS
Thanks for that! I’ll still have to run each gauge (oil fuel and temp) to its correct sender, ampage to alternator and tach to coil though won’t i?
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
05-12-18 08:25 AM - Post#2733766
  • Jordie Said:
Hi all,
Cheers
Wow, quite a project. We cannot help with a RH drive harness first of all. Next, the 65 dash is hard wired and did not use a printed circuit like the 67 does. They are not even remotely close to being able to work. In addition, if it is a true gauge cluster with live gauges and tach, the ammeter will never work properly if at all. The ammeter circuit was based on a given length of wire in the shunt circuits (105 and 106), and when you change the length of those wires, the gauge does not work properly, and will usually melt the traces on the PC board. You are going to have to create you own harness using the connections form the 67 PC board and the 65 dash, and do not wire or use the ammeter. No easy answer. In addition, the 65 and 67 cars are not pinned out the same at the firewall. Wish I could be more positive and offer a better solution, but I can't.
Donny
Jordie
Loc: Australia
Reg: 10-02-13
05-12-18 05:37 PM - Post#2733814
    In response to aawtech
Thanks mate that does help a little
So apart from the ampage meter I’d just hook the other up as usual? Oil pressure to sender, fuel to sender, temp to sender, tach to coil and speedos obviously normal? lol
Jordie
Loc: Australia
Reg: 10-02-13
05-19-18 12:08 AM - Post#2734312
I have successfully got the 67 original gauge cluster working properly with the 65-66 wire harness.
But using the lights on the 65-66 (or Australian built 67) harness I had to add two extra lights. I then made my own power harness and ground harness for the tach, (earthed to cluster) water temp, fuel and ampage meters. I then have each gauge running to its correct sender. They were all easy to figure out except the ampage gauge, it takes some work. But if anyone needs a diagram to create the harness I’m happy to help out
Execution time: 0.282 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:00 AM
