Username Post: 2-3 shift flare        (Topic#350930)
Hohnsz71
Loc: Dayton Texas
Reg: 02-23-15
05-02-18 06:24 AM - Post#2732837
If you are thinking about getting a cold air intake for your 5.3 07-13 1500 truck with the 6l80, you will need a tune. The TCM uses data from the MAF to help manage torque when shifting. With a cold air intake installed the velocity of the air passing the sensor changes and gives an invalid reading to the TCM. This caused my 2-3 shift flare. The flare went away after I installed the factory intake back on the truck.
2012 silverado, bone stock.
Execution time: 0.48 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:09 AM
