Username Post: my take on the lower intake        (Topic#350831)
markj
markj
Loc: ocean co,nj
Reg: 01-15-04
04-27-18 08:24 AM - Post#2732365
2001 s10 200k 4.3
no issues while working , but I would recommend taking fan off if I had known.only did lower gaskets only, removed whole thing upper with lower.
truck started after a time, but started and ran fine.
drove mostly local checking for leaks and just keeping an eye out.
started it one morning and had a awful tap, thinking this was a lazy lifter. let idle till warm and it did sort itself out. going to use it this morning and a dash light which I am unfamiliar "check gauges"
pooped up, saw there was no oil pressure, "sigh". don't know if this is related to repair, or is it time to retire truck.
thanks for tuning in
mark
07 2500 silverado classic
duramax lbz allison 6 speed
01 chevy s-10
2015 Honda odyssey
99 HD FLSTF
04 bmw r1150rt
2013 FLHTK
markj
markj
Loc: ocean co,nj
Reg: 01-15-04
04-29-18 05:46 AM - Post#2732505
    In response to markj
update:
removed distributor and checked oil pressure switch.
dripping oil at electrical connection.
ordered one from Napa.
also gonna try a heavier oil, maybe the lifter will stop leaking down.
there is hope yet.
Mark
01 chevy s-10
2015 Honda odyssey
99 HD FLSTF
04 bmw r1150rt
2013 FLHTK
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
04-29-18 10:25 PM - Post#2732596
I doubt heavier oil will fix your lifter problem
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
Senior Chevytalk Moderator
04-30-18 02:54 PM - Post#2732668
    In response to SleeperSS
200,000 is okay. I had one at 229,000 and kept going to 250,000 plus after I sold it. I'm not sure what the final mileage was when I found it on craigslist for sale. It was basically ruined. Have you taken the valve covers off to look for a damaged rod or broken rocker arm?
markj
markj
Loc: ocean co,nj
Reg: 01-15-04
05-03-18 08:52 AM - Post#2732943
I have not, the tap did go away after warming up.
having changed the oil to a heavier grade, it seems to go away faster, but still there on cold start.
now researching a po420 code. one headache at a time.
thanks
Mark
01 chevy s-10
2015 Honda odyssey
99 HD FLSTF
04 bmw r1150rt
2013 FLHTK
markj
markj
Loc: ocean co,nj
Reg: 01-15-04
05-12-18 06:22 AM - Post#2733757
Quick update, valve tap, gone, worked itself out I suppose.
replaced o2 sensor right bank.was going to do the quick fix with the spark plug extender but didn't.
truck runs fine.
one issue I have had though, secondary air pump has not worked . ever. has anyone had experience with this?
thanks Mark
01 chevy s-10
2015 Honda odyssey
99 HD FLSTF
04 bmw r1150rt
2013 FLHTK
05-13-18 11:20 AM - Post#2733871
It has a secondary pump? Is it a Kali model?
markj
markj
Loc: ocean co,nj
Reg: 01-15-04
05-15-18 08:28 AM - Post#2734025
po410
secondary injection system
with my old reader I cannot erase just one code
it clears all, dang.
trying to get threw inspection now
thanks mark
01 chevy s-10
2015 Honda odyssey
99 HD FLSTF
04 bmw r1150rt
2013 FLHTK
Edited by markj on 05-15-18 08:28 AM. Reason for edit: No reason given.
05-15-18 09:39 AM - Post#2734030
After codes are cleared, it must go through a drive cycle test. The test go "pass" for emissions.
Does the valve have a vacuum hose on it?
05-15-18 09:41 AM - Post#2734031
I found this video on a secondary pump.
https://www.youtube.com/watch?v=5cJGaft0-xI
markj
markj
Loc: ocean co,nj
Reg: 01-15-04
05-16-18 04:46 PM - Post#2734128
thanks for that informative video.
over 90 miles since I installed new 02 sensor.
dmv said still not ready, damn.
it does have a vac port,
truck is beginning to get on my bad side.
thanks
mark
01 chevy s-10
2015 Honda odyssey
99 HD FLSTF
04 bmw r1150rt
2013 FLHTK
markj
markj
Loc: ocean co,nj
Reg: 01-15-04
05-17-18 04:56 PM - Post#2734210
yanked the pump out, easy pull. 2 bolts,2 hose clamps, vac hose,elec connection.
disassembled on bench, motor , no bueno.
did all I could do with baby vice grips to spin.
and yes, water.
before installing new motor, gonna try drilling weep hole and put plug in for maintenance purposes. we will see.
thanks
mark
01 chevy s-10
2015 Honda odyssey
99 HD FLSTF
04 bmw r1150rt
2013 FLHTK
Execution time: 0.311 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:51 AM
