Username Post: Anyone running a 2004r?        (Topic#350647)
z28summit
Infrequent Contributer
Reg: 06-11-14
04-16-18 08:42 AM - Post#2731161
Looking to see what you have done for a cross member.
kzhurley
kzhurley
Loc: Millersburg,Ohio
Reg: 01-02-12
04-16-18 07:40 PM - Post#2731223
    In response to z28summit
Before I put the 4-speed in my 50, I had a 2004r behind my 348. I removed most of the original frame bracing except where the brake master cylinder mounts up.
I then bought a 4 inch drop tubular universal trans cross member from speedway motors and also got the top-hat style ends got it. Then it's pretty much cut to length and weld it up then bolt it in.
1950 Styleline Deluxe 2-door sedan..
348 tripower/NP833 4-Speed/3.73
1950 Styleline Deluxe 4-door..
Vortec 4200 I-6/4l60e/3.42/current project car
1956 Cadillac Coupe de Ville 500 efi/4l80e
1987 GMC R1500 Sierra Classic
454 tbi/700r4/3.42
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
04-16-18 08:10 PM - Post#2731230
Hi Z28. I do my own but use a design that is very similar to the Walton's product.
Because they loop over the tail and have a dropout section underneath they give you both strength and remove ability.
When you take out the original member you remove a lot from the original frame, given you almost always do this to put more power through it I believe it is very important to replace that strength and reinforce it to the rear.
Hence I would recommend that you also fit a rear shock cross member to help support the rear frame. Walton's also make these. Theirs are bolt in as the frames vary a bit, but there is nothing to stop you bolting them in then running a couple of supporting beads.
If you had an Oldsmobile it would already have this member.
Cheers Kiwi.
ps. When doing a trans member always remember your car will have an exhaust system, and if it's real low it will potentially need to go over or through the trans member.
Edited by Bel Air kiwi on 04-16-18 08:13 PM. Reason for edit: No reason given.
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
04-16-18 09:44 PM - Post#2731240
Walton Mfg. in my 53, with 700r4.
Johnnie
1950 styleline deluxe sports coupe, 350 cid, TH 400, nova rear end. Gen IV Vintage air. SOLD!
1953 210 4 Door, 235 with Powerglide. All original except for the 1954 hood bird.
John 3:16
z28summit
Reg: 06-11-14
04-17-18 05:48 AM - Post#2731267
    In response to kzhurley
KZ,
So the 4 inch was the correct amount of drop?
When you mentioned the top-hat style ends, are referring to the ends that come in with the 55-57 cross member kit?
Thanks,
50hotrod
50hotrod
Reg: 07-25-11
04-18-18 07:50 AM - Post#2731407
This is the Walton Mfg. crossmember. The trans is a 700R4.
Attachment: progress_3.jpg (93.91 KB) 3 View(s)
This is the Walton crossmember.
People done gone put their Bible's away
Edited by 50hotrod on 04-18-18 07:52 AM. Reason for edit: No reason given.
04-18-18 08:37 AM - Post#2731411
When In installed the Muncie over 50yrs ago, I went with the KISS principle (Keep It Simple stupid) it simple. I used a 55-57 style bell housing, had brackets welded to the frame for stock 55-57 bell housing mounts, retained bone stock 51 Chevy clutch linkage, cut the center our of the stock transmission cross member and then sandwiched it back in with steel plates.
Oh ya, and my warped philosophy regarding auto trannys----------------"T hey should all be thrown in the river"!
Attachment: 100_4111-1.jpg (49.97 KB) 0 View(s)
Attachment: 100_4112-1.jpg (62.02 KB) 1 View(s)
Attachment: 100_4114-1.jpg (62.76 KB) 0 View(s)
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
04-18-18 07:23 PM - Post#2731495
Hi DZ, there isn't one right answer. But I am sure you would consider the Walton method if you had to do another one.
That to me is the beauty of these forums. We continually get to look at and see other ways of doing things and the answers just keep getting better.
As I have said many times I would use Walton's stuff if the freight wasn't so prohibitive.
There is also another aftermarket style where you slip one tube inside the other to deal with the width variances of frames.
Requires a full circumferential weld all round each end.
Easy with the body off, but not everybody is going that direction.
Cheers Kiwi
z28summit
Reg: 06-11-14
04-19-18 02:43 PM - Post#2731577
I would have to do some trimming and modification in order to get the the Walton 7004r one to fit the 2004r. I'm not against doing this, but I if can find a decent one without the need to hack into it I may go that way.
04-19-18 06:59 PM - Post#2731611
  • kzhurley Said:
Before I put the 4-speed in my 50, I had a 2004r behind my 348.....
What did you do about the parking brake linkage?
Execution time: 0.412 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:33 AM
