Username Post: No Start. RESOLVED!!        (Topic#350637)
Blueseasons
Reg: 10-13-11
04-15-18 03:56 PM - Post#2731079
Easy fix: The wire from the distributor cap to coil popped off the cap. Don't ask me how. Replaced plug wires, cap, rotor, and distributor module. Thanks all for the help!!
Truck started fine twice today. Third time no start. Engine turns over. Fuel pump is only a few years old but I think its not getting spark. Starting fluid made no difference. Turned on the radio to wait for tow and radio pre-sets were gone. This suggests to me that the problem is electrical. Dash lights work, Inside fuses look good. 88 K1500, 350. Any help would be appreciated.
Edited by Blueseasons on 04-20-18 07:53 AM. Reason for edit: No reason given.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
04-15-18 04:28 PM - Post#2731085
    In response to Blueseasons
Just because you know how old the fuel pump is doesn't mean it's good. A lot of them are bad out of the box.
Can you hear the pump prime? What is your battery voltage? Don't use the gauge, use a multimeter. Are your battery cables tight?
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
Blueseasons
Reg: 10-13-11
04-15-18 05:02 PM - Post#2731086
    In response to bowtie44s
I have never heard the fuel pump prime the whole time I have owned the truck,(7 years). The engine turns over, the battery has plenty of juice. I think the cable connection is good because the starter works. The starter fluid didn't get the engine to catch. If it did, the engine would have caught and run for as long as the fluid lasted. I'm not ruling out the fuel pump but since the starter fluid didn't help, am assuming there is no spark.
04-15-18 05:15 PM - Post#2731089
Check for loose connections on the firewall at the distribution block, passenger side under the big plastic cover. A loose one there might explain why your starter is getting normal power but other circuits seem to have glitched out on you.
Blueseasons
Reg: 10-13-11
04-15-18 05:41 PM - Post#2731096
    In response to someotherguy
I looked in there while I was waiting for the tow truck. I didn't fiddle with anything though. It looked old under there. I have never touched anything in there over the last 7 years of ownership. I left it in a mechanics parking lot for now but I have to go over there with the keys tomorrow and I will look then. All the other electrical seems to work except the pre-sets and that may not mean anything.Just thought I would only mention it just in case. I love my truck. It's been as reliable as time. Most people I know at 30 years old aren't as in good a shape as it is.
evhfan2000
evhfan2000
Loc: Portland, OR.
Reg: 10-17-04
04-15-18 06:36 PM - Post#2731102
I have had bad battery connections cause the exact same problem. It can be VERY intermittent.
One time I literally tightened the positive battery cable 1/4 turn to snug it up and problem went away.
I've also had hidden corrosion in the positive cable. Someone here told me to inspect my positive cable better heading towards the starter. I found serious corrosion inside the cable cover/housing. So bad I had to buy a new cable battery to starter.
Dean
65 Impala Sport Coupe
99 CK2500 4x4 7.4L Crew
03 CK1500 4x4 5.3L Sub
02 CR250R
Execution time: 0.286 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:53 PM
