Username Post: 2008 yukon wheel hub grease        (Topic#350632)
thealexdexter
Reg: 01-03-05
04-15-18 02:15 PM - Post#2731061
I need to replace hub. Prefer to use oem spec grease but having trouble locating part number. Anyone have a FSM to look up correct grease?
2015 CC 3500 Duramax Sierra All Terrain 4x4 SLT in Black
2008 Yukon Denali in Black
04-15-18 05:16 PM - Post#2731090
    In response to thealexdexter
These are sealed unit bearings, no grease involved - what's in 'em is what's in 'em.
thealexdexter
Reg: 01-03-05
04-16-18 10:50 PM - Post#2731244
    In response to someotherguy
The replacement videos I’ve seen show greasing the outside before install. Not needed?
04-17-18 10:33 AM - Post#2731291
Haven't seen those videos, care to link one? I'll take a wild guess though and assume they're probably just trying to prevent it from corroding inside the knuckle, making it hard to remove next time. If that's the case then pretty much any grease would be fine, just general chassis type grease or even a very thin coat of anti-seize.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-17-18 01:28 PM - Post#2731317
I've seen grease recommended on the seal behind the hubs, but I don't know if the new trucks have a separate seal.
I'll be using anti-seize to keep my new hub from sticking. I think it will stay in place better, and it's made for that kind of thing. Plus, I have a gov. surplus pint can of it
99 K3500 RCLB
thealexdexter
Reg: 01-03-05
04-17-18 08:35 PM - Post#2731365
https://youtu.be/eqXknVcvYIM
You are probably right. Anti seize is likely the reason.
Execution time: 0.279 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:03 PM
