Username Post: violent op gauge        (Topic#350626)
04-14-18 09:09 PM - Post#2731006
anybody ever seen a violent oil pressure gauge reading? its maybe 15-20 psi range vibrating wildly at 40-60 psi maybe 2-3k rpms
04-15-18 06:27 AM - Post#2731022
    In response to bobb
Mechanical or electrical? Mechanical could be air in the tube. Electrical could be a bad sender.
IgnitionMan
Reg: 04-15-05
04-15-18 09:02 AM - Post#2731029
    In response to bobb
What brand oil filter, hope it isn't a Fram?
04-15-18 09:53 AM - Post#2731034
    In response to IgnitionMan
haha, i never use fram filters. this ones a napa wix 1794. gonna try bleed the line. hmm maybe change the filter too if bleeding wont work
IgnitionMan
Reg: 04-15-05
04-15-18 01:29 PM - Post#2731054
    In response to bobb
Only reason I asked is that with Fram, there are a LOT of flow problems, from the filter materials obstructing oil flow through them, filter end plates, made from paper, coming apart from the filtering media, and......check valves in the filter doing a rapid open/close/open/close situation.
There might also be an issue with the valve in the oil filter adapter as well.
Any lifter noises?
Did it do this all at once, or gradually?
I had a friend with a pickup truck that had this happen, mechanical gauge, plastic tubing from engine to gauge. It started all of the sudden, not so much, then got worse. when he finally brought the truck by my place, we found he had simply drilled a hole in the firewall, and poked the tubing through it, and along the way, the firewall metal had worn the plastic tube away on one side of it. We moved the hose, engine stopped, and it broke. It was on the way to failure, big time, finally gave up the war.
Just have to look at all the areas.
malibu101
Loc: Walnutport PA
Reg: 11-20-00
04-16-18 06:59 PM - Post#2731221
I (and others I know) have used NAPA 1794 2 quart filters for many years on SBC's without a problem. But quality control problems can happen.
My opinion, great choice of filter!
I've heard of guys bleeding the line to the oil pressure gauge to get rid of the air. I personally have never seen this as being a problem. But I haven't seen everything.
Sorry I don't have an answer for your problem. Just saying what I've experienced.
IgnitionMan
Reg: 04-15-05
04-16-18 08:04 PM - Post#2731229
    In response to malibu101
I like the 2 quart filters as well.
Execution time: 0.228 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:32 AM
