Username Post: Fuel pressure in HHR        (Topic#350597)
kmdakota1
Reg: 04-05-18
04-12-18 01:59 PM - Post#2730804
Specs are in for psi testing. Here's what i have.
Engine running- 58 psi
Key on and engine off- 52 psi
after 12 min- 48 psi
after 21 min- 40 psi
after 31 min- 32 psi
Do these numbers look normal? The pressure does drop (looks like 8 psi every 10 mins) and i'm guessing eventually to zero but i stopped after 31 mins. I am also noticing gurgling sound in fuel tank after putting this pump in. Does not sound normal. WTH!!!
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-14-18 07:09 PM - Post#2730996
    In response to kmdakota1
If those are engine off with key on (KOEO)
Then I would say that is good.
As long as it is good while it is running.
It will drop with KOEO as the pump only runs once for a few seconds to prime.
It runs continously while running
Old School GM fan FOREVER
Execution time: 0.401 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:22 PM
