Username Post: 5.3L Engine Issues        (Topic#350588)
tendrew7
Loc: Chattanooga, TN
Reg: 10-22-12
04-11-18 04:17 PM - Post#2730735
I've run into a few problems and I need some information and advice. I have a 2009 5.3L with AFM. I've had a check engine light on for a while telling me there is a misfire on cylinder two. After exhausting all the external possibilities, I decided to dig a little deeper and see what I could find. Not good.
Issue one, after I got the intake off, I noticed some oil around the intake gasket around most of the intakes. Is this normal? It uses a little oil, but the exhaust has never had a burnt oil smell.
Issue two, after I took the valley pan off, I found the source of the misfire. One the roller lifters froze and cut a groove into the camshaft lobe about a 1mm deep. I know that the camshaft and rollers need replaced, but can I get away with reusing the old camshaft bearings or do they need to be replaced with the camshaft.
At this point, I'm trying to decide if I want to button it back up and sell it, just deal with the camshaft issue, or just bite the bullet and rebuild the engine.
Any input is greatly appreciated.
04-11-18 06:32 PM - Post#2730750
    In response to tendrew7
Couple of issues here, the metal from the cam damage may have gotten through the engine. Before going further I would pull the pan and look at some bearings. Rods and mains. If any damage is evident, the engine needs to come apart. If they look ok, pull the cam, you will see if the cam bearings look bad.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-14-18 08:00 PM - Post#2731001
Can you buy a used engine?
99 K3500 RCLB
Execution time: 0.267 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:04 AM
