Username Post: 1963 Impala Legroom/Headroom        (Topic#350546)
msp177
Reg: 02-16-10
04-09-18 05:57 AM - Post#2730441
Anyone know how to create more legroom/headroom
1963 Impala? The bucket seats are like small sofas and with the seat all the way back it feels cramped...steering wheel is awfully close to the bucket seat as well.
Any solutions, ideas, or thoughts out there?
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
04-09-18 08:45 AM - Post#2730453
    In response to msp177
here is a option that my friend did in his factory 63 SS Hardtop (with studs for the seat brackets on the floor).
The plates in the picture are 3 inches long and 1 1/4 inches wide. The holes in them are the same size as the slotted holes in the bucket seat brackets. The screws holding them on have tapered heads so they hold in place & they are installed vertically so they fit flush with the floor pan/brackets.
Paul
Attachment: 63_chevy_ss_buckets_007.jpg (198.42 KB) 7 View(s)
SS bucket seat extenders -moves seat back 2 inches using the factory floor studs on all SS cars
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Website http://paulstensland.com/
[image]http://chevytalk.org/sm/26453.jpg[/ima
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
04-09-18 10:29 AM - Post#2730460
    In response to pvs409
smaller steering wheel, 1" smaller makes a huge difference
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
04-09-18 11:31 AM - Post#2730469
You can gain 1 inch more leg room by opening up the forward most seat track holes to 3/8" and using them to attach to the floor.
msp177
Reg: 02-16-10
04-10-18 03:53 AM - Post#2730533
So, it looks like the bracket extenders would use one hole instead of 2 on the outer bracket, correct?
msp177
Reg: 02-16-10
04-10-18 03:55 AM - Post#2730534
    In response to turbo38s10
Did that and now I need to modify the directional signal lever as its too close to the steering wheel and gets in the way. Anyone done this?
msp177
Reg: 02-16-10
04-10-18 04:01 AM - Post#2730536
    In response to 55Brodie
That's an interesting approach. There is no reason why you couldn't modify the seat position via the seat frame. That would likely be the best way to push the seat back further undetected. I suppose you would only be limited by the frame itself if you drilled new holes to push the seat back further. Likely you would need to make this adjustment for both driver and passenger buckets.
Do you happen to have any pics of this modification?
Thanks,
M
msp177
Reg: 02-16-10
04-10-18 05:39 AM - Post#2730543
55 Brodie, have you seen this? Did it make that much difference?
55Brodie
55Brodie
Reg: 12-26-15
04-10-18 09:55 AM - Post#2730570
Yes I did it on my 62 SS bucket seat tracks. The holes are aleady there, but are the wrong diameter. They need to be drilled to 3/8" diameter.
I'm 6'5" with a healthy gut and I have the 17" deep dish 59/60 Impala steering wheel. Everything clears fine after I bent the spaghetti floor shift handle about 10 degrees to the right for knee/thigh room.
msp177
Reg: 02-16-10
04-10-18 10:19 AM - Post#2730574
Get that. I thought these cars were bigger. Not so, at a mere 6' 1" x-football player I hit my head on the roof rail when getting into the car. The Grant (smaller) steering wheel still feels like its in my lap but its probably better than a full size wheel.
I also had the bucket seats redone and they are like mini sofas and don't give very much so not only are you close to the windshield but you feel like your head is almost touching the headliner. I just don't recall my 56 Belair being like that but that was many moons ago.
All I can figure is the average person back in the day was shorter and had stumps... wife doesn't have an issue at 5' 5". Perhaps I give her the car and say have fun! Sure would be a sight to see her floor it and get sideways with 500 hp under the hood.
Perhaps I can take the driver seat back to the upholsterer and use a lower density foam so the seat would give more and sit down a bit.
Thoughts?
55Brodie
55Brodie
Reg: 12-26-15
04-10-18 11:01 AM - Post#2730578
The knots on my head have finally scabbed over and toughened up.
I dont recall these problems back in 69 when I had my first 62. Of course that was 100lbs ago and I was a lot more agile then.
Edited by 55Brodie on 04-10-18 11:02 AM. Reason for edit: No reason given.
msp177
Reg: 02-16-10
04-10-18 11:17 AM - Post#2730581
I guess the older you get the more comfort you need. No problem with my X5...plenty of clearance.
Execution time: 0.262 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:32 AM
