Username Post: Electrical issues        (Topic#350537)
old_gto
Needs to Get Out More Member
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
04-08-18 03:45 PM - Post#2730379
Hello everybody! It`s been a very long time since I`ve been on. We`re finishing up the 65 Fleetside, and are having electrical problems.
Let me get you caught up. We swapped the 292 six for a 1966 283, with a T350 trans. All new wiring harnesses, new switches & sending units, flashers, bulbs & bulb sockets. The ONLY original electrical piece is the instrument cluster.
The engine starts, & runs smooth. But we`re having the following issues....
1. Rear tag light and both tail lights work, but when brakes are applied, left side lights up, but right side goes out. Right side also goes out when right turn signal is turned on.
2. When left turn signal is turned on, left rear lights up, but is on constant & does not flash.
3. Front parking lights work, but if either left or right turn signal is turned on, both flash at the same time.
4. Headlights do not work with pull out switch, unless dimmer switch is pushed, then low beams come on. Lights will then go off with pull out switch, but will not come back on unless dimmer is pressed again. No high beams work at all.
5. Instrument panel lights work, but dome light does not.
6. Turn indicators on dash both flash at same time if either left or right turn signal is turned on.
So, any electrical gurus that may be able to help "shed some light" on our predicament? (Pun intended)
The only thing I`m sure of, is that I`m not sure of anything.
71 Corvette, 97 burb, 66 GTO, 69 Grand Prix, 65 Mustang, 65 C-10 Fleetside, 74 Camaro
Too many toys, not enough play time!
bobschevytrucks.com Ecklers
jktucker92
jktucker92
Reg: 02-05-17
04-09-18 11:09 AM - Post#2730468
    In response to old_gto
Did you replace the turn signal switch? It can cause a lot of these issues. It shouldn't affect the headlight issue or the dome light, but it can definitely affect the brake lights and turn signals. The turn signal switch has several metal pieces inside that switch power to the rear brake/turn signal light between the brake circuit and the turn signal circuit. I remember pulling it apart and bending and cleaning the contacts inside several times to get it to work properly.
old_gto
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
04-09-18 12:56 PM - Post#2730470
    In response to jktucker92
Yes, it`s new also.... but that doesn`t mean it`s any good, considering all the junk I`ve bought from China in the last couple years! We`ll pull it apart and take a look, THANKS!
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
04-10-18 05:19 AM - Post#2730541
No electrical guru here but I have done a lot of electrical work including wiring several cars from scratch without a kit. It's hard to diagnose electrical problems without being there but here is my opinion. I think number 1 is being caused by a bad ground. Be sure the light housings are grounded properly. Flashers will not work unless both front and rear on same side have good bulbs front and rear. Make sure both the front and rear bulbs are good. I think number 3 is bad wiring. Somehow you have both front light signals wired together rather than separately. I think number 4 is either a bad dimmer switch or another wiring snafu where the headlight switch is being fed from the dimmer switch. Power should go to the headlight switch first and then to the dimmer switch and then to the headlights. Most dome lights are hot all the time and work only when grounded. Make sure that there is power going to the dome light and that when it is turned on from the headlight switch that it becomes grounded. The turn indicator problem on the dash is related to the wiring issue on the front directional signals and should clear up when that is corrected. Those are my guesses. Wiring can be very frustrating. Good luck.
Vern
1953 Chevy Belair Sport Coupe - 350 Crate Engine,700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 4-Wheel Disc Brakes, Nova 10-bolt, Chassis engineering front suspension.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
04-16-18 03:46 PM - Post#2731197
Were you able to get any of your wiring woes corrected?
Vern
old_gto
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
04-18-18 12:57 PM - Post#2731428
Running redundant ground jumpers from light buckets to frame.... but everything seems to be pointing to a faulty turn signal switch. We found a skinned wire, and another one was loose. That switch was new.... but so was the stop light switch that fell apart in my son`s hand, LOL! Will post an update when we get it all cleared up.
Execution time: 0.229 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:15 AM
