Username Post: battery drain Part V        (Topic#350315)
rod
Loc: kingman,az
Reg: 04-29-00
03-27-18 10:37 AM - Post#2729116
2000 S-10 Blazer.
I finally found the drain. in the underhood fuse box, 10 amp fuse for the TBC, Truck Body Computer. on the amp scale, set at 200M, the reading is .230, which, as I understand is many times higher that allowable [that being .030 to .050, depending on who states a #].
as is, when I park the Blazer, let the battery set to normalize, it will read about 12.45 V. the next morning it will read 12.05V.
the question is now: what do I do about it?
I am tired of disconnecting the battery, so I am putting a quick disconnect switch on when it gets here.
appreciate any answers/help.
thanks Rod in AZ
Senior Chevytalk Moderator
03-27-18 02:24 PM - Post#2729130
    In response to rod
What are the power body accessories? The TBC controls: power windows, power mirrors, air conditioning, immobilizer system, central locking, and other options. Which one does not work? Which one has recent work done on it?
rod
Loc: kingman,az
Reg: 04-29-00
03-28-18 04:55 PM - Post#2729259
great, more things to check. seriously, thanks for the next step. I will get started on that tomorrow.
will let you know what I find.
Rod in AZ
rod
Loc: kingman,az
Reg: 04-29-00
03-29-18 08:47 PM - Post#2729354
    In response to rod
results so far. the underhood draw was .21. I checked all the dash fuses, and found the interior courtesy lights, when no lights were lit, was drawing .10. so that is half the problem. I just went out in the dark and checked for any lights being on. glove box light goes off. it appears there is no ash tray light [have to get a mirror and check that tomorrow] I cannot see any other light. I did find a fish eye light switch broken, but that is all plastic, so it shouldn't be able to short out. another thing to check in the day light.
no other dash fuses had any draw. am at a loss as to where the other .11 draw is.
more soon Rod in AZ
Execution time: 0.225 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:34 PM
