Username Post: Wiring Issue, 1967 Corvette        (Topic#350109)
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
03-14-18 02:48 PM - Post#2727604
I have already posted this saga on the CorvetteForum, so if it looks familiar, that's why.
I have a neighbor who has a 1967 Corvette with electrical issues. I have no experience with Corvettes, but have been around Chevrolets for many years. I currently own 3.
Yesterday, his running (parking) lights worked (both front and rear), as did tail/brake/backup, turn signal, emergency flashers and license lights. Rear harness had issues until we cleaned the connections, which got everything back there working. However, we had no headlights.
Per a great suggestion from the guys at CorvetteForum, we decided to check connections at the dimmer switch. When we removed the carpet to get to the switch and wiring, we found the plug had become disconnected from the switch (probably happened when the owner installed the carpet). Hooked it up and we got headlights!
Now, here is the strange thing: we now have no taillights (they worked yesterday, before we got the headlights going) and we keep blowing the 20A taillight fuse. So, we clearly have a short somewhere, related somehow to the new condition of having the headlights working. We will get in there tomorrow and try to find the short.
Meanwhile, if anyone here has encountered (and fixed) this problem in the past, and can pass along a few hints, we would be most appreciative.
1953 3104 1/2 Ton Truck
1965 Impala SS 327/M20
1965 Chevelle SS 327/M20
VCCA #47487
AACA #446449
bel-air 62
Reg: 01-16-05
03-14-18 04:12 PM - Post#2727619
    In response to bajones238
You say you cleaned the connections but did you also clean the ground wire that goes to each individual light? Remember that the ground wire has to be cleaned at both ends.
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
03-14-18 05:14 PM - Post#2727628
    In response to bel-air 62
All the grounds checked good but I will have another look at both ends, as you suggest. Thank you!
VCCA #47487
AACA #446449
bel-air 62
Reg: 01-16-05
03-15-18 04:04 AM - Post#2727662
Corvettes have a tendency to all kinds of weird things because unlike other cars they need ground wires to each light. Any one of these that isn't properly grounded will affect other lights, doesn't always make sense but is common.
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
03-15-18 01:42 PM - Post#2727715
We got everything working, finally. It turns out we had several problems:
1. Dimmer switch disconnected.
2. Bad flasher with expired capacitor across its terminals.
3. Dirty connections inside several harness plugs.
4. Bent contact inside one taillight socket, causing a short to ground.
Thanks to bel-air62 for the suggestions.
VCCA #47487
AACA #446449
Edited by bajones238 on 03-15-18 01:43 PM. Reason for edit: No reason given.
bel-air 62
Reg: 01-16-05
03-17-18 09:58 AM - Post#2727937
Glad you was able to find the problems, Corvettes can be a pain!!
Execution time: 0.201 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:39 AM
