Username Post: 1953 Bel Air convertible        (Topic#350081)
Gerhard Snyman
Reg: 03-13-18
03-13-18 06:53 AM - Post#2727442
Hi I just bought a 53 Bel Air convertible. I’m unable to ID the engine. The engine serial, LAK730578. Top casting 3836848 ( I think the top is a after fit. The car has a three speed manual shift. I think it might be a 235 ( not oil pressured ).
I would also like to find out more about the car. The body plate is missing is there any other place that I could find it in the car. The person I bought it from gave me the following info.
Style 53, 1067, DTX
Body No 1887.
Trim 267
Paint 503.
Where can I track the history of this car my plan is to restore it to concourse condition.
Thanks.
Gerhard
eplantage
Loc: Southern MN
Reg: 03-15-04
03-15-18 11:59 AM - Post#2727700
    In response to Gerhard Snyman
You may get more responses if you were to move your post to the main forum instead of the classifieds. I have a '53 convertible myself that's been a project for a number of years. Good luck with yours.
Age: 63 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
03-15-18 08:06 PM - Post#2727779
    In response to eplantage
Done
03-15-18 11:25 PM - Post#2727790
1067 DTX is a '53 Bel Air convertible.
Have you looked for the cowl tag on the firewall cowl--on the passenger side?
The 3836848 head is a later 235 head--'56 to '62, or maybe later if it's a replacement head. It has the larger hole for the electrical heat temp sending unit. The head's casting date will be under the valve cover.
My 2-bit guess is the engine was changed at some point to the later full pressure 235.
When it's running what does the oil pressure read?
And what does the oil pressure gauge read? 0-30 or 0-60?
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
03-16-18 05:50 AM - Post#2727799
Hi Gerhard, As Robert has said the casting number you have given is for a cylinder head, this number was the standard one for post production parts sales.
If you look down on the block by the distributor you will find the Block casting number. It is not easy to see but it will be there and tell you what motor you have. It may be under the engine mount.
I put a piece of clean paper on the number and rub it with my hands to get the numbers.
Once you have the number you can look it up online.
http://chev235guy.blogspot.co.nz/ This site may help
Cheers kiwi
Edited by Bel Air kiwi on 03-16-18 06:19 AM. Reason for edit: No reason given.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
03-16-18 06:33 AM - Post#2727804
The engine block is correct for a 1953 Passenger car and more specifically for a non-PowerGlide passenger car. I am guessing that the "K" is Kansas City. I have heard that some folks have been able ro find the car's serial number stamped on the top of the left frame rail about where the fender and door meet....especially on 1953 convertibles.
1951 Fleetline
Mirango53
Infrequent Contributer
Loc: France, Bordeaux
Reg: 10-07-16
03-17-18 01:47 PM - Post#2727966
    In response to RAM_51
Hello , you share with us photos from your car
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
03-26-18 06:59 AM - Post#2728979
    In response to Mirango53
Yes, we LOVE convertibles!
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
Gerhard Snyman
Reg: 03-13-18
04-04-18 07:58 AM - Post#2729897
Hallo Gents,
Thanks for all your information.
Pictures to follow.
Gerhard
Execution time: 0.321 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:20 PM
