Username Post: 2004 Chevrolet Silverado lifter        (Topic#350079)
Reg: 03-13-18
03-13-18 04:42 AM - Post#2727428
I have a 2004 Silverado 1500 with a 5.3, it only has 75000 miles. I have always changed the oil regularly, all of a sudden in the last month a lifter will tick really badly at start up and it will smoke really bad. Only does it about once a week. Especially after its been run and it sits for about two hours. Just looking on incite on this. Hard for me to believe that with that low of mileage I am having this problem.
Loc: Parsippany, NJ
Reg: 10-08-02
03-13-18 05:43 AM - Post#2727434
    In response to JJhooks
Google Castech heads and you will see numerous threads on the cracked head issue. My friends 04 had the same issue with smoking on start up. I did all the valve seals on it & it didn't help a bit. We ended up swapping out the heads on it, and no more issues.
I would check to see if you have the Castech heads, and go from there... aste...
Execution time: 0.284 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:05 PM
