Username Post: Oil Eater...Get Yourself Some        (Topic#350041)
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
03-10-18 09:13 PM - Post#2727162
Valve and rocker arm shaft bolts and head bolts that spent over 50 years bolted up and covered with ‘gunk’ and removed a few years ago. Pulled out the 4 shaft bolts and soaked over night in a 25 /75 oil eater and water solution. No need to have them vatted. The results speak for themselves.
Attachment: 1B473B81-1E45-4400-80F8-3155D68C4B5D.jpeg (1.78 MB) 6 View(s)
Attachment: 98D2EF62-0993-4448-889E-C40B8FCD64C9.jpeg (664 KB) 4 View(s)
Attachment: B7CA41B0-FBFF-4EF6-8622-16D07B8200C5.jpeg (1.9 MB) 5 View(s)
50s Chevys http://www.picturetrail.com/sfx/album/view/245196 4...
03-10-18 11:16 PM - Post#2727167
    In response to 50sChevys
Wow Jack. Impressive. Thanks for posting that.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
03-11-18 03:05 AM - Post#2727172
And where did you buy it?
1951 Fleetline
2blu52
2blu52
Reg: 03-12-02
03-11-18 07:09 AM - Post#2727188
Right on time with the tip. The cleaning solvent in my parts washer is around 16 years old, more like thin grease than solvent. I have a complete set of rocker arms that need to be cleaned up, got them off a 216 oil burner and need to see if they are usable or not.
THOMAS JEFFERSON
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
03-11-18 07:44 AM - Post#2727192
    In response to RAM_51
https://www.walmart.com/ip/Oil-Eater-Cleaner- Degre...
Here you go Ram.
whiskey1954
Gold Supporting Member
whiskey1954
Loc: central north carolina
Reg: 12-07-08
03-11-18 04:55 PM - Post#2727230
Thanks 50's 2 weeks late but! I got it ordered tonite. Late meaning replacing front steering sector and decided to do engine and bay under hood. This product would have been perfect for that instead of what I used which made a heckuva mess in my garage. But this will help clean it up !!!!
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
03-11-18 06:36 PM - Post#2727242
  • 50sChevys Said:
... in the Tri-Five Chevy isle
Sheldon Y.
Loc: Waltham, Massachusetts
Reg: 10-29-16
03-12-18 05:36 AM - Post#2727289
    In response to kool53
I Drink a glass, once a month, Cleans me right out!
What's the cost? 'Cause I use old Gasoline with the same results, and it doesn't cost me anything but a few Brain Cells! (Washed my entire engine, sanded, and painted all in the same day).
'49 Styleline Deluxe Build@
https://www.jalopyjournal.com/forum/threads/49-sty...
http://www.frankenrodz.com/frankenstyle.html
2blu52
2blu52
Reg: 03-12-02
03-12-18 06:24 AM - Post#2727294
    In response to Sheldon Y.
And a small spark would put an end to it all!
THOMAS JEFFERSON
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
03-12-18 06:51 PM - Post#2727383
Wow Jack! Thanks for the tip.
Jalapeno
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
03-12-18 07:09 PM - Post#2727386
    In response to Jalapeno
Good to hear from you man!
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
03-13-18 08:42 AM - Post#2727462
just ordered me some. been using kerosene. maybe i can get away from that. thanks
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
14 camaro (new)
bry593
Reg: 10-07-13
03-13-18 08:48 AM - Post#2727464
    In response to 62chevy427
I use kerosene too, but I still have to spend time with a brush. Apparently, this stuff is simply dunk and rinse off the next day? I like the sound of that!
Execution time: 0.475 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:32 PM
