Username Post: 1946 Chevy 1/2 Ton        (Topic#350014)
03-08-18 11:43 PM - Post#2726961
I am correct that in order to change out the battery, that you have to remove the rubber floor mat and then the floor pan.
Has anyone modified the floor pan to remove the battery?
bobschevytrucks.com Ecklers Chevy Trucks
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
03-10-18 11:31 AM - Post#2727122
Keith, isn't there a cover plate in the floor pan to access the battery? Group 16.547 COVER in the illustration below.
Attachment: Conventional_Cab_-_Exploded.jpeg (1002.73 KB) 19 View(s)
1951 Fleetline
03-10-18 03:09 PM - Post#2727139
    In response to RAM_51
That cover only covers the battery caps, for adding water to the battery. You have to remove the complete floor pan to change out the battery. Will post a picture once it stops raining.
RAM_51
RAM_51
Reg: 12-28-02
03-10-18 03:52 PM - Post#2727142
Caps only...Wow! Does it maybe slide out from below?
1951 Fleetline
03-10-18 07:08 PM - Post#2727155
I don't think it can, but will have to check. The battery in there is okay, but I want to be ready when it does quit.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
03-11-18 08:38 PM - Post#2727255
Hi Keith, sorry I only have an AD model. That has what looks like a bigger door. But it's still not easy to lift out without a handle on the battery.
The actual battery box bolts onto the chassis on mine but you probably need the battery out to remove it.
Hard to imagine they built them without a serviceable battery access.
If you want to change yours the AD lid is a cheap repro available all over.
Cheers Kiwi
Edited by Bel Air kiwi on 03-11-18 08:40 PM. Reason for edit: No reason given.
03-11-18 11:35 PM - Post#2727270
    In response to Bel Air kiwi
I think I am going to make a cut where that dip is in the floor pan and then make that into a door and screw it in. That way there is plenty of room to access the battery. The way it is you cannot even remove the cables. Got some pictures today, but will post them tomorrow as it is time to get to bed.
03-12-18 09:47 PM - Post#2727408
Pictures of floor pan and battery from underneath. Looks like it needs a battery box.
Attachment: Floor_Pan.JPG (1.81 MB) 21 View(s)
Attachment: Floor_Pan_2.JPG (1.92 MB) 20 View(s)
Attachment: Battery_from_Underneth.JPG (2.57 MB) 19 View(s)
RAM_51
RAM_51
Reg: 12-28-02
03-13-18 03:31 PM - Post#2727496
Wow...not a very friendly design. Bel Air kiwi mentioned the access door in the Advanced Design 47-55 trucks. It does offer a lot more room to do everything that you'd need to do with the battery to include installation and removal. If you had room to install that in your truck it would make a much nicer alteration. My battery access door measures 9 1/4" X 12 1/2". It would be a matter of cutting the opening out of one of the AD trucks and welding it into your floor...IF room allows.
Attachment: IMG_1217.jpg (3.61 MB) 20 View(s)
Attachment: IMG_1215.jpg (3.65 MB) 19 View(s)
Attachment: IMG_1216.jpg (3.12 MB) 20 View(s)
1951 Fleetline
03-13-18 09:26 PM - Post#2727526
I had some folks on another site said to leave it stock. I figured I could make one cut across it and then us the cut piece to make a screw in door. I did see on utube, a 46 with a battery box under the hood on the firewall, drivers side. I don't have access to my pickup right now, but will check it our.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
03-14-18 05:20 AM - Post#2727548
Hi Keith, If that larger floor panel doesn't come out then I would tend to go with a firewall side battery box if you are also going 12V.
The aftermarket AD piece will bolt onto a flat, or near flat panel. It is between $40.00 to $50.00 and the hold down frame another $20.00.
If you put this on the passenger side firewall you are close to the starter and it will look factory to most folk. I would put big washers or plates on the inside so it didn't tear the firewall.
I would also powder coat or two pack the parts to avoid acid deterioration. I would also use nylon washers/spacers to hold it off the firewall so when you hose it down it clears all the residue.
Cheers Kiwi
Attachment: 341-4047_800.jpg (17.41 KB) 16 View(s)
Attachment: 340-4047_800.jpg (21.67 KB) 19 View(s)
Attachment: s-l640.jpg (53.02 KB) 16 View(s)
Edited by Bel Air kiwi on 03-14-18 05:27 AM. Reason for edit: No reason given.
RAM_51
RAM_51
Reg: 12-28-02
03-14-18 06:44 AM - Post#2727558
I am one of those "stock" guys too so I understand folks saying that. Another alternative would be fabricating or finding a separate floor, putting an access whole and lid in that one and keeping the original floor. There is an original on eBay now...[see below]... and they seem to make re-pops of these as well. I know! I know! A simple fix is getting more and more expensive!
LINK:
https://www.ebay.com/itm/1941-1942-1946-Ch evy-GMC-...
1951 Fleetline
monty56
monty56
Reg: 04-26-04
03-14-18 09:30 AM - Post#2727574
Brothers Trucks Maybe something like these drop-down trays could be adapted. Searcyh DDBT059
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
03-17-18 08:09 AM - Post#2727927
Hi Guys, if the whole floor comes out without moving the seat then just fix the battery box and use sealed batteries. Most new ones are anyway.
I guess that might not be the case if you stay 6V
Cheers Kiwi
03-17-18 09:34 AM - Post#2727934
    In response to monty56
Never thought of that.
03-17-18 09:36 AM - Post#2727935
Looks like the floor comes out, but after you pull the rubber mat and maybe pulling the gear shift lever on the transmission. Don't want to tear the mat.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
03-26-18 01:45 PM - Post#2729016
Hi Keith, how does the factory battery box attach to the frame? Are they made aftermarket? Can you fit in a latter one where it is.
Cheers Kiwi
Execution time: 0.302 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:27 PM
