Username Post: 95 CHEVY CRANKS BUT WONT START        (Topic#350012)
ChevyZdog
Reg: 03-08-18
03-08-18 08:55 PM - Post#2726947
Got a 95 chevy z71 5.7 350 tbi .. ill start at the beggining i parked the truck for about a month due to front end issues but i got that squared away and started driving it again recently well i took a trip out of town about 60 miles away it drove fine i parked it . The next morning i tried to crank it it turned over but would not start so i shot some starter fluid in it(my first time using ever on this truck)and it kinda hesitated but it started and i drove it home . As days went on it got harder and harder to crank(3 days tops)til starter fluid would not start it. Ive changed ignition coil , pick up coil, ignition control module, engine control module or computer and spark plugs still no start i dont think im getting any fire or fuel anymore my mechanic says he smells fuel but the problem has him stumped ..
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
03-08-18 10:12 PM - Post#2726951
    In response to ChevyZdog
Sorry you spent a lot of money on parts you may not have needed. You have a fuel delivery problem.
Please get your hands on an Actron TBI fuel gauge and adapter. Your local parts store may have a loaner program.
Screw it into the supply feed at the back of the TBI.
Pressure needs to be at least 9psi.
Pressure check:
Key on, engine off
You can’t start it right now so that’s the best you can do.
Greg
'00 Explorer XLT 4.0 V6 Auto
03-09-18 07:21 AM - Post#2726976
Welcome to Chevytalk,
From our FAQ post at the top of the forum, here's a link on troubleshooting a no start condition: http://www.chevytalk.org/fusionbb/showtopic.php?ti...
ChevyZdog
Reg: 03-08-18
03-09-18 09:39 AM - Post#2726991
    In response to CowboyTrukr
U say fuel problem ? Well i did a shade tree spark test with the number 1 spark plug wire and a screw driver and i still get neither blue spark or red spark . Nd if it is fuel how do i fix a fuel pressure problem ? Fuel pump or injector ? And shouldnt it have cranked if i shot starter fluid in it after all the new parts if its fuel ?
ChevyZdog
Reg: 03-08-18
03-09-18 10:22 AM - Post#2726998
I ALSO FORGOT TO MENTION THAT WHEN I CHANGED MY PICK UP COIL ON THE DISTRIBUTOR IT WAS FULL OF OIL . OIL HAD THEN TRAVEL UP THE DIST. ALL ONTO THE PICK UP COIL . COULD MY DIST. BE BAD ?
Chevytech
Chevytech
Reg: 04-25-04
03-09-18 10:41 AM - Post#2727003
If there is oil coming up the shaft and getting out onto the pickup coil – replace the distributor.
I wonder if someone put a distributor from an older vehicle in your truck. Around 1989-1990 the distributor shafts didn't have the groove in the shaft to direct oil "back" down into the engine. Oil would get into the pickup coil and can damage the coil windings. Any of the distributors can do this if they get very worn.
On these distributors the housing/upper bushing area can get so worn out that the shaft will move sideways so far that the points on the pickup coil pole piece get hit by the reluctor points on the shaft. When this happens the ECM receives compromised signal for RPM and timing issues.
The distributor shaft should not move side to side when you try to wiggle it sideways.
Edited by Chevytech on 03-09-18 10:45 AM. Reason for edit: No reason given.
ChevyZdog
Reg: 03-08-18
03-09-18 12:50 PM - Post#2727023
    In response to Chevytech
Going get a Dist. Now soo do i take off Dist. Cap off do i try to wiggle it then ?
Chevytech
Chevytech
Reg: 04-25-04
03-09-18 02:46 PM - Post#2727040
Yes, if you take the cap off the distributor and try the wiggle the shaft sideways and it moves, the distributor needs to be replaced.
Chevytech
Chevytech
Reg: 04-25-04
03-09-18 05:05 PM - Post#2727050
It sounds to me like this is way beyond of your knowledge on the topic.
The timing of when the spark happens and which cylinder it goes to is dependent on the position of the rotor/shaft when you install the distributor and the timing is altered by rotating the distributor housing.
My concern is if you remove the distributor you will lose the timing position and then there is little chance you will get it running again.
ChevyZdog
Reg: 03-08-18
03-10-18 05:48 AM - Post#2727095
I understand your concern but i know a little bit on setting it number 1 cylinder to top dead center the rotor cap facing the number 1 spark on dist.cap setting the harmonic balance to 0
ChevyZdog
Reg: 03-08-18
03-10-18 05:50 AM - Post#2727096
Ive got places marked umder my hood to tell me where to set things even the harmonic balance is marked
Execution time: 0.492 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:53 AM
