Username Post: How to reset/fix "change engine oil soon" notice for 2011 Tahoe Z71        (Topic#350011)
Bluthundr31
Loc: Silicon Valley area, Cali...
Reg: 03-06-18
03-08-18 07:28 PM - Post#2726934
I didn't see anything in the owners manual about how to "reset" or "fix" an annoying "change engine oil soon" notice that comes up at start-up. It says my "oil life is 4%".
Does anyone know how to get this notice cleared??
Any help would be appreciated.
Bluthundr31
Reg: 03-06-18
03-08-18 07:33 PM - Post#2726937
    In response to Bluthundr31
I went to a different site and found this, so I'm passing it on here so someone else can benefit from the information, , , ,
here ya go
1. Turn ignition key to ON position (do not start)
2. Depress accelerator pedal three times within 10 seconds
3. Watch DIC for reset notice
4. Turn off ignition, or repeat above steps if you screwed it up
Sharing information is the most important part of having a site like this!!!
elcamino
elcamino
Reg: 03-30-00
03-09-18 05:46 AM - Post#2726969
Right side of cluster should be a 4-button pad called the Driver Information Center (DIC). Push the "Car!" button till oil life remaining is showing, then press and hold the check button (lower button) while oil life remaining is displayed. Will take a few seconds to clear and should beep and go to 100%.
2016 Polaris RZR 900 EPS
Bluthundr31
Reg: 03-06-18
03-10-18 12:31 PM - Post#2727129
    In response to elcamino
Thanks Mike, I think your procedure is the proper way to do it and works!!!
Execution time: 0.681 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:32 PM
