Username Post: Nv4500        (Topic#350008)
Dynamutt
Reg: 08-03-15
03-08-18 04:40 PM - Post#2726915
I have 86 1 ton dually 2 wheel drive. It has sm465 with gear vender overdrive. Would like to replace with nv4500. Has anyone else done this swap? Can I use my stock bell housing and clutch? Was told to get tranny from a dodge because they use speedo cable. Sure could use some info. Thanks
Edited by Dynamutt on 03-08-18 04:40 PM. Reason for edit: No reason given.
03-08-18 10:38 PM - Post#2726955
    In response to Dynamutt
The NV4500 will not bolt to your SM465 bellhousing. If you don't want to swap the bellhousing, you can use this adapter with a Dodge NV4500.
http://www.advanceadapters.com/products/712550--do...
Dynamutt
Reg: 08-03-15
03-09-18 07:21 AM - Post#2726975
Thanks I'll check into it
03-09-18 10:26 AM - Post#2726999
If you don't mind my asking, what is your reason for wanting to replace the SM465 + GV?
Dynamutt
Reg: 08-03-15
03-09-18 10:48 AM - Post#2727004
The first overdrive was trouble free for over ten years. Replaced it 2 years ago when it failed. I've been through 6 replacements since then. I'm tired of it. Need something I can depend on.
03-09-18 10:55 AM - Post#2727006
Wow! That's disappointing to hear about GV. These are warrantied units from GV, or...?
Dynamutt
Reg: 08-03-15
03-09-18 12:03 PM - Post#2727016
    In response to someotherguy
Yes there under warranty but what a pain in the censored. I have to pull it out , box it up take it to ups wait a week or so to get replacement and then reinstall . So I'm without my truck for a couple of weeks. Plus 2 qts synthetic fluid and gas. Just got to be a better way.
03-09-18 01:15 PM - Post#2727027
I'm surprised to hear that the GV can be so troublesome. Until now, I hadn't heard anything bad about them, other than the difficulty of repairing them because of their complexity. I'm used to the Borg-Warner OD, so of course the GV does seem complex to me. It has a lot of the elements of an automatic transmission.
Anyway, now I can fully understand why you want to get rid of it. Thank you for explaining.
2plus2
Loc: Mission,BC
Reg: 02-03-05
03-09-18 06:23 PM - Post#2727057
Just run the chevy nv4500 with a electric speedo&drac setup from a 90-91 blazer/burban or search around summit/jegs for a generator that reads the electic vss and spins the speedo cable
https://www.speedhut.com/Speedbox.html
https://ck5.com/forums/threads/conver ting-89-cable...
69 Canadian Pontiac 2+2
Edited by 2plus2 on 03-09-18 06:30 PM. Reason for edit: No reason given.
03-09-18 08:37 PM - Post#2727072
    In response to 2plus2
I'm glad to see that Cable-X now has a competitor. Unfortunately, it doesn't look like there is any competition on price.
Execution time: 0.342 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:25 PM
