Username Post: Can't figure out brake pull. Help!?        (Topic#350003)
Schiavoneluke
Reg: 05-16-16
03-08-18 11:03 AM - Post#2726887
Here's another one that I've been struggling with. Brakes pull hard right. Could really use some thoughts on this one
Have played with the adjustment at least a dozen times. Might solve it for a day but cones back
Appeared shortly after a brake job with new pads last year but not until about halfway through a 200 mile road trip almost out of nowhere
After it started pulling I changed:
-wheel cylinders
-flex hoses
-tried rotating drums-no change
-new front end kit including ball joints, tie rod ends, etc
- no visible signs of contamination. Have tried cleaning the pads and drums with rubbing alcohol
Sometimes it feels like it's pulling when I'm driving straight down the road, but all suspension components were replaced. What else is there to look at? Breaks pull, squeak, and jump when braking from high speeds, shaking the whole car
Edited by Schiavoneluke on 03-08-18 11:05 AM. Reason for edit: No reason given.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
03-09-18 06:33 AM - Post#2726973
    In response to Schiavoneluke
Are you sure your alignment of the front end is correct? These cars used to pull like crazy if the alignment was off.
msp177
Reg: 02-16-10
03-09-18 08:46 AM - Post#2726987
I assume you have drums all around? If so...
1. Have you turned the drums?
2. Are the drums within wear tolerance?
3. Did you have the brakes adjusted?
4. Have you had an alignment?
That's about it for what you describe. Hope this helps!
msp177
Schiavoneluke
Reg: 05-16-16
03-09-18 11:06 AM - Post#2727009
    In response to turbo38s10
Ive had a shop look at the alignment at least 3 or 4 times now . Unless their machine is off it should be good
Edited by Schiavoneluke on 03-09-18 11:06 AM. Reason for edit: No reason given.
03-09-18 12:01 PM - Post#2727014
If you pull the drums, does the contact wear area look similar on all of the shoes?
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
03-09-18 12:27 PM - Post#2727022
On my 2008 Impala, it was doing pretty much the same thing. It turned out the front tires were bad where you couldn't see. Internally they were separating. When you braked, the whole car would shake.
George
64ss409
Reg: 12-04-02
03-09-18 04:23 PM - Post#2727045
Are the primary and secondary shoes in their correct positions?
Schiavoneluke
Reg: 05-16-16
03-09-18 06:10 PM - Post#2727053
Well not exactly. It appeared as though the top and bottom of the pad had slightly more wear on the primary shoe and some of the brake dust seemed to have collected in this area. But I tried sanding it down and cleaning the shoes and it didn't seem to change anything
Schiavoneluke
Reg: 05-16-16
03-09-18 06:10 PM - Post#2727054
    In response to 64ss409
Yes small shoes are towards the front
Schiavoneluke
Reg: 05-16-16
03-09-18 06:15 PM - Post#2727055
    In response to gkralik3645
Good thought. I'll try rotating them
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
03-10-18 07:42 AM - Post#2727100
-wheel cylinders
-flex hoses
"Have played with the adjustment at least a dozen times. Might solve it for a day but cones back"
Sounds like adjustment is at least part of your problem. If they don't pull immediately after they are adjusted correctly, then perhaps there is something wrong with one of the adjusters (or some other part) that does not allow that brake to stay properly adjusted.
A leaking brake cylinder can cause rather severe grabbing too.
Have you figured out which wheel is the culprit? The one grabbing and causing the 'pull' will lock up first.
If the car is in its 'pulling' mode now. Recommend you get the wheels off the ground and see if the adjustment is still correct.
Hope this is helpful.
Pete
Schiavoneluke
Reg: 05-16-16
03-10-18 02:55 PM - Post#2727137
    In response to japete92
Turns out it was a bad brake shoe. Rotated the shoes and got the adjustment even and it started pulling to the left. The one primary shoe had seriously more wear when I compared it to the others. Thanks everyone for your help.
junky
Loc: Northeast CT
Reg: 06-27-10
03-10-18 06:30 PM - Post#2727152
Assuming that both sides were replaced at the same time, one shoe being worn more than the others, would indicate a problem with the hydraulics or the return springs. It will be up to you to figure out which one it is. If you replaced both wheel cylinders, is there a possibility that they are not a matched pair.. i.e. diameter of the cylinder? Are the brake hoses a matched pair? Did you replace the brake hardware?
Blu 67
Blu 67
Loc: Oshawa, Ontario Canada
Reg: 10-15-05
03-10-18 08:21 PM - Post#2727159
    In response to junky
Try one of the infra red heat guns to check brake temps. Will point you in right direction.
Can be used for many more application as. How hot is your coffee?
67 Impala 2 Dr Hrdtp, Edelbrock intake,ceramic headers,3 speed TH350 auto.,aluminum radiator,350 Crate motor Daily driver in the summer. Sitting on a 68 station wagon frame Owned for 39 years.
2017 Upgraded to Classic Auto Air Conditioning .
56_Kruiser
56_Kruiser
Loc: St. Augustine, Fl
Reg: 09-23-05
03-11-18 06:48 AM - Post#2727185
    In response to Blu 67
JFYI...
I had a pulling problem for years. It manifested differently than yours. It was inconsistent, sometimes left, sometimes right. I went through all the changing of everything like you.
EXCEPT...A-Arms.
I had aftermarket a-arms on the front. Don't remember the brand...I put them on in 1983. The purpose was to allow better alignment. (I don't recall what, seems caster or camber sometimes needed improved control arms).
At any rate, they ultimately spread at the top a bit, and would allow them to shift forward or backward. Depending on whether they were forward or backward, or centered, it would pull left, right, or not at all.
Doesn't take much shift to affect things.
I replaced with Global West expensive...but what a difference in handling. And pull gone.
1956 Belair Convertible
Drone Video of "Sherbet"
models916
Loc: Addison, IL
Reg: 05-28-10
03-12-18 05:32 AM - Post#2727287
    In response to 56_Kruiser
Rubber hoses clog from the inside and reduce pressure to that side of the brakes.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
03-12-18 06:58 AM - Post#2727297
    In response to models916
How can reduced pressure cause a brake to pull?
junky
Loc: Northeast CT
Reg: 06-27-10
03-12-18 07:18 AM - Post#2727301
There is more pressure on the opposite side of the car that has more flow, so the braking pressures are not equal. Mismatched brake linings can cause the same problems. Even worn wheel bearings can cause strange problems, that is why I always replaced them in pairs. If one side has worn out, the other side isn't far behind. The only way to totally check for defective parts, is to swap all mechanical brake parts from one side to the other and see if the problem moves to the other side. If it doesn't then the problem is in the hydraulics. I suggest that you have someone else that is experienced, put eyes on it. Possibly they will see what you are not seeing.
hallgastrap
Loc: illinois
Reg: 10-07-13
03-12-18 11:14 AM - Post#2727336
try rotating front tires
models916
Loc: Addison, IL
Reg: 05-28-10
03-13-18 04:54 AM - Post#2727429
    In response to Tri5man
They don't clog the same left to right and pull the way of the higher pressure/volumn. I went through this with a 66 wagon I had that pulled.
Schiavoneluke
Reg: 05-16-16
03-15-18 08:48 PM - Post#2727782
D idnt change the a arms but they are original and appeared fine when we were doing springs and bushings. Not sure how you would determine if they were a problem
Schiavoneluke
Reg: 05-16-16
03-15-18 08:50 PM - Post#2727784
Brake hoses have both been replaced a second time, wheel cylinders were checked and the diameters were all the same. Did find it unusual that one wore more but I thought maybe the material was just defective
Execution time: 1.278 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:01 PM
