Username Post: VACUUM        (Topic#350002)
D5ofusc
D5ofusc
Loc: Dallas TX
Reg: 03-01-18
03-08-18 10:47 AM - Post#2726884
can anyone tell me how much vacuum pressure i should be getting at an idle?
350 small block
D
Edited by D5ofusc on 03-08-18 10:47 AM. Reason for edit: No reason given.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
03-09-18 07:27 AM - Post#2726977
    In response to D5ofusc
Depends on the intended purpose of the engine. If you’re asking about bone stock, then 18-20 should be good.
Here’s a chart from a thread by one of the learned greats here at CT:
Greg
'00 Explorer XLT 4.0 V6 Auto
Senior Chevytalk Moderator
03-11-18 05:57 AM - Post#2727179
    In response to CowboyTrukr
Engine specs make a difference. For tuning, adjust the carb for max vacuum at idle and cruise RPMs. 17 hg or above is ideal.
D5ofusc
D5ofusc
Loc: Dallas TX
Reg: 03-01-18
03-12-18 11:28 AM - Post#2727337
Yea bone stock .
D
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
03-12-18 11:55 AM - Post#2727340
350 small block
While not a 350, my old 305 should be very comparable considering stock cam and idle speed, etc at the time. With a well tuned Q-Jet and a properly timed HEI, I was pulling 22 in/hg in park at 650 rpm. In drive at 550 rpm it was about 18-19 in/hg. With a 204/214 @ .050 RV cam and edelbrock performer RPM intake, knock 2 in/hg off those values at the same idle speeds.
Edited by 1983G20Van on 03-12-18 11:58 AM. Reason for edit: No reason given.
D5ofusc
D5ofusc
Loc: Dallas TX
Reg: 03-01-18
03-13-18 05:45 AM - Post#2727435
    In response to 1983G20Van
ok thnx very much
D
Execution time: 0.884 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:33 PM
