Username Post: Engine magnets        (Topic#349985)
Am4wag
Reg: 11-19-15
03-07-18 10:57 AM - Post#2726751
Where can they be got?Any special type?
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
03-07-18 01:10 PM - Post#2726758
    In response to Am4wag
That depends. What in particular are you trying to use them for? Are you talking magnetic drain plugs, oil filter magnets, parts picker uppers (technical names escape me there), transmission filter magnets, I mean there is a lot left to the imagination.
"8 cylinders of why the f&@% not" - me
Am4wag
Reg: 11-19-15
03-07-18 07:00 PM - Post#2726799
    In response to Junkyardwarrior
To put in the lifter valley and oil pan (shrapnel catcher)...
65_Impala
Reg: 12-29-02
03-08-18 11:22 AM - Post#2726895
Most any rare earth magnet big enough for that use would work then. Ebay or Amazon will have many different types available. Use some 2-part epoxy to hold them in place.
You can also find ones with holes that could be bolted down, but there usually aren't many suitable threaded holes in an engine.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
03-08-18 01:52 PM - Post#2726909
    In response to 65_Impala
reading links can provide you with a great deal of related info
normal magnets and computer magnets loose the ability to trap debris at higher oil temps
65_Impala
Reg: 12-29-02
03-08-18 09:25 PM - Post#2726949
    In response to grumpyvette
Grumpy, you might be right. A NdFeB magnet might not be stronger than a SmCo magnet at 100*C. I doubt they would permanently lose their magnetism in an engine though.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
03-09-18 07:30 AM - Post#2726978
https://www.kjmagnetics.com/blog.asp?p=temperature...
https://www.kjmagnetics.com/blog.asp?p=magnet-grad...
https://www.supermagnete.de/eng/faq/What-temperatu ...
https://www.magnet4sale.com/smco-magnets-dia-3-4x 3...
proper magnets trap metallic debris
SmCo Samarium Cobalt Disc Magnets
http://www.magnet4less.com/
http://www.magnet4less.com/product_...ucts_id=254&...
http://www.magnet4sale.com/smco-magnets-dia-1x3- 8-...
Samarium Cobalt MAGNETS HELP
http://www.magnet4sale.com/smco-disk-magnet-dia- 1x...
magnets are ceramic and glass hard, don,t try to drill or grind them, as they can shatter
Edited by grumpyvette on 03-15-18 06:34 AM. Reason for edit: No reason given.
03-09-18 07:13 PM - Post#2727064
Back in the old days with iron heads, I just laid a cheap magnet a little bigger than the drain back hole in each end of the head. Worked great and caught the valve spring debris.
Epoxying a similar one in the drain back hole on an aluminum head will work the same way.
Virtually all of the stuff you want to catch is from the valve springs.
You can overthink this.
Execution time: 0.945 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:47 AM
