Username Post: 2008 Colorado w/ OBD P0452        (Topic#349972)
goofyfish
Loc: Frederick, MD
Reg: 02-25-05
03-06-18 11:54 AM - Post#2726663
Hey gang -
Got a code for Evaporative Emission Control System Pressure Sensor Low Input (Pending Fault). The CEI came on while passing another vehicle and I had to really tromp on it. Everything I read says this does not effect performance, but I have 20% drop-off in mileage. What should I be diagnosing here?
'95 K1500 4X4 Ext. Cab, 5.7L, 4L60E - Stock From Top To Bottom
217K - 3.73 Ltd Slip Rear - HD Tranny & Oil Coolers
'02 K1500 4X4 Ext. Cab 103K
'08 Colorado 53K
'95 Yamaha FX1 Superjet
'02 23' Bayliner Rendezvous
'04 Yamaha GP 800
2blu52
2blu52
Reg: 03-12-02
03-06-18 04:22 PM - Post#2726682
    In response to goofyfish
A common cause of that light is a loose gas cap or failing seal on the cap. My older Buick did something similar and cured it by resetting the gas cap. Finally had to replace the cap.
THOMAS JEFFERSON
03-07-18 07:50 AM - Post#2726734
Google that code and you will find the common causes.
goofyfish
Loc: Frederick, MD
Reg: 02-25-05
03-08-18 01:29 PM - Post#2726907
    In response to 2blu52
  • 2blu52 Said:
...cured it by resetting the gas cap. Finally had to replace the cap.
Yah, tried that first thing since it's cheap. No joy.
'08 Colorado 53K
'04 Yamaha GP 800
goofyfish
Loc: Frederick, MD
Reg: 02-25-05
03-08-18 01:31 PM - Post#2726908
I did, and they are all over the road with no mention of the mileage loss. So, looking for someone that might have some experience with the same issue. Thanks for your... input.
'08 Colorado 53K
'04 Yamaha GP 800
03-08-18 08:00 PM - Post#2726940
Focus on the evapleaks code, the mileage may not be related. There are several good trouble trees referring to this code, there is no set one time answer/fix for this.
Senior Chevytalk Moderator
03-11-18 04:27 AM - Post#2727175
Start searching for a vacuum leak. What size engine is in it? Engine configuration gives clues. As LS engines get older, I'm seeing more coming around for maintenance. I've found the intake gaskets are starting to fail. A quick and carefully used water bottle can be used. Basically, pour a little water down the intake mating surface. If the engine idle changes and it runs rough, the intake gasket is failing. Follow this video: https://www.youtube.com/watch?v=h8rxpfRvHf8
Just in the last week, I've seen two failing. One in a 6.0 Denali and a 5.3 Trailblazer.
Execution time: 0.313 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:42 PM
