Username Post: 47 RAG TOP--REAR END BOUNCES!!        (Topic#349963)
Broo102
Broo102
Loc: RANCHO CUCAMONGA, CA.
Reg: 09-30-14
03-05-18 10:21 PM - Post#2726605
My car really bounces in the rear when I hit a bump!
When I was building my car 2 years ago, I used a camaro rear end. Bought new Posie leaf springs and I think the rear shocks came with them.
I built an upper bar for the shocks to attach, but I couldn't stagger them (one on one side of the bar, one attached to the other side)
Anyone know, is that why the rear bounces so much?
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
03-06-18 08:02 AM - Post#2726633
    In response to Broo102
It sounds like you need new shocks.
cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
lofat46
2nd Year Silver Supporting Member
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
03-06-18 09:12 AM - Post#2726642
Broo,
Is it a bounce like worn out shocks? Step on the rear bumper and see if the how many times the car rocks before stopping. If it comes right back up and stops the shocks should be good. Perhaps you just need a softer shock. Or is it a hard bounce like possibly the springs are too stiff? If there aren't many miles on the car perhaps the springs just need t to wear a little more. Maybe a leaf has to come out.
I don't know it it makes a difference but are your shocks straight up and down or angled slightly? The Chassis Engineering kit I have in my '46 sedan has both shocks mounted on the same side of the upper shock mount/crossmember but the tops of the shocks are angled towards the center of the car I'm guessing about 30 degrees. Maybe remove the shocks or disconnect the the lower shock mounts and take the car for a short drive. This might tell you if it's stiff springs or the wrong shocks.
1946 Chevy Fleetmaster 4-door Street Rod
Edited by lofat46 on 03-06-18 09:13 AM. Reason for edit: No reason given.
Broo102
Broo102
Reg: 09-30-14
03-06-18 09:27 PM - Post#2726704
    In response to lofat46
Thanks Tony
The car has about 800 miles on it, the springs are those super soft design I believe. The shocks are at an angle toward the center of the car (I think Ill take a look)
I know the springs are the lowered version they sell.
If I stand on the rear bumper, it doesnt bounce up & down much; I already tried that.
The bounce i can describe is not a bottoming out type of thing its more like if I go over a speed bump, the front takes it normally, but the back "bucks" me out of my seat practically! Looks funny, cuz if it were a hard top I would hit my head!
Broo
Thanks!
Bru
John 3:16
lofat46
lofat46
Reg: 08-12-13
03-07-18 08:17 AM - Post#2726739
Hmmm,another possibility is that the shock is bottoming out going over a bump because there isn't enough travel when the shock is "collapsing" while going over a bump.
Broo102
Broo102
Reg: 09-30-14
03-07-18 11:13 PM - Post#2726825
you know, I never thought of that!
Thanks!
Bru
John 3:16
Broo102
Broo102
Reg: 09-30-14
03-08-18 09:23 AM - Post#2726869
Im wondering if the car is too light in the rear.
I was thinking of adding a couple of 50 lb. bags in the trunk and testing it.
Thanks!
Bru
John 3:16
lofat46
lofat46
Reg: 08-12-13
03-08-18 12:05 PM - Post#2726898
Hey, it's worth a try, but you don't want to add an extra hundred pounds to the car all the time. Takes up too much trunk room.
Broo102
Broo102
Reg: 09-30-14
03-11-18 06:20 PM - Post#2727240
Right, just for demo purposes
Thanks!
Bru
John 3:16
Execution time: 0.813 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:59 PM
