Username Post: Lower Control arm shaft        (Topic#349954)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-05-18 04:47 PM - Post#2726546
Can I take the shaft loose and change the shaft without taking it completely out of the car.
I'm thinking I can jack the car up on jack stands.Take the drivers side wheel & tire off and jack under the a arm and unbolt the shaft then remove the shaft and old bushings and then replace it all back.
Am I just wishful thinking?
Not asking is it the easiest way just wondering if I can do this. I'm just not real sure about the old one holding up.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
blkss64
Reg: 07-22-12
03-05-18 08:22 PM - Post#2726584
    In response to Andy4639
Please, for your own safety, do not attempt what you described! Trying to replace the control arm shaft and bushings with the arm in the car will not work. Once you remove the shaft bolts there is nothing to hold the load of the spring except the shock, and that surely will give way. There are tools and techniques to use. If you have never performed this repair, seek the help of someone who has or take it to a professional.
Edited by blkss64 on 03-05-18 08:25 PM. Reason for edit: No reason given.
gofastwclass
Loc: In the garage
Reg: 08-19-14
03-05-18 08:58 PM - Post#2726593
    In response to blkss64
I agree with blkss64.
Essentially you will be spending a lot of time and creating a potentially dangerous situation in an effort to save a few minutes.
If you are trying to remove the lower control arm shaft you will need a press. If the bushings are bad enough you don't need a press to get the arm out you will likely need one to get it back in. To do this job properly, you need a decent coil spring compressor, a hydraulic press and a bit of experience, patience and all the usual tools including one of several options to remove a ball joint from the spindle without damage.
A good, undamaged (key words good, undamaged) shock will hold the spring in place, but you will be fighting under the car creating nothing but a hazard for yourself and comedy for the onlookers.
I'm sure I'm not alone in the fact that I would rather not read about you from a friend or widows perspective next week and how you were a great guy who loved cars, etc.
If you do attempt this task in the manner you describe, please will me your cars and tools first.
1961 Impala mild custom build
I build my own stuff...
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-06-18 04:26 AM - Post#2726612
    In response to gofastwclass
Ok guy's come down, that's why I asked! First off yes I know the spring will be held in place by the shock and as I said I'd have the jack under it also.
This is why I asked. I guess I'll be pulling the control arm this weekend. I have the spring compressor and the pickle forks for taking it a part. I'm hoping I want need a press but if I do I have a neighbor who has one.
Oh by the way my grandson gets all of my vehicles!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 03-06-18 04:27 AM. Reason for edit: No reason given.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
03-06-18 02:24 PM - Post#2726674
You will need the press for sure. Not an easy job at all. It takes experienced shops half a day to do both sides. I wanna say I paid $300 or so to get both control arm bushings replaced last year. If you are thinking of replacing the springs, this would also be the time to do it.
Shane
64 Impala SS: 350 4 speed
"Let's go Reds"
junky
Loc: Northeast CT
Reg: 06-27-10
03-06-18 03:20 PM - Post#2726675
The shock bolts to the bottom side of the lower control arm, so there is no way to get the control arm off, without first removing the shock. Once the lower control arm is out, you will need a machine shop to press out the old, and press in the new. Not a job for a novice, unless you have someone experienced working with you.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-06-18 06:37 PM - Post#2726691
    In response to junky
The new shaft & bushings slide right together. I got the shaft from Ecklers with bushings and hardware. I hope I can get the old bushing out and then install the shaft then slide the bushing's in to the control arm and use my neighbor's press and press the bushings into the arm and on to the shaft ends. I plan to grease the shaft well also.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 03-06-18 06:45 PM. Reason for edit: No reason given.
junky
Loc: Northeast CT
Reg: 06-27-10
03-06-18 07:49 PM - Post#2726697
A word of caution. If the "ears" of the control arm are not properly supported, you run the risk of bending them, causing you to replace the control arm, instead of being able to reuse it. This is what happened with my upper control arm, when I had the bushings replaced by a local mechanic. One ear bent in slightly, and it was enough to cause a constant squeak. I just replaced it, and when the bent control arm was placed alongside of the replacement, it was clearly bent, even though it didn't look like it in the car.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-07-18 04:04 AM - Post#2726717
Thanks for the tip. I'll make sure they are supported good. Hope to get it off tonight and the old bushings out. I got the car on jacks and the front wheel off yesterday after work before we left for birthday supper.
Tonight is free nothing else planned so I hope to get the spindle off and the arm out. If that goes well I'll see how much trouble the old bushings are to get out.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
1963er
1963er
Loc: Joppa, Md.
Reg: 12-20-15
03-07-18 05:34 AM - Post#2726720
I used an air chisel to get my old ones out...
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-07-18 06:42 PM - Post#2726795
    In response to 1963er
Well I must be living right guy's!
I started taking the lower control arm off today after work. The spring compressor I had wouldn't go inside the lower arm hole to go into the spring. So I wrapped a chain around the upper arm and frame through the spring to hold it in place while I took the fork to the lower ball joint. It worked like a champ. Not that I would want to do it that way every time but it did just fine.
Ok the arm comes off with no problems so I put it in my vise deciding on how to proceed. I took my 2 lb small sledge hammer and a big center punch and 2 blows each both bushings fell out! I'm telling you I must have done something right.
So I cleaned up the bushing area good and I put a small amount of grease on the bushing and inside it and used a old socket and again 2 hits and they are seated. I was pleased to say the least.
The only thing is the shock nuts inside the lower arm are stripped out. The shock was nutted so I think I'll get some nuts and weld them in before reassembly. It will make it a lot easier to put back together.
Hopefully I'll finish up tomorrow before bed time.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
junky
Loc: Northeast CT
Reg: 06-27-10
03-07-18 07:31 PM - Post#2726802
Try to find some grade 8 nuts for the lower shocks. Run a bolt into the nut, to hold it into place when you weld it to the control arm.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-08-18 04:22 AM - Post#2726834
That's what I plan to do. Ace hardware has bolts, nuts & washers grade 8.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
03-08-18 04:41 AM - Post#2726836
Awesome!! its nice when a hard job ends up being easy. We all know that easy jobs have been hard a time or two.
We all deserve a break sometimes.
Shane
"Let's go Reds"
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-08-18 05:38 AM - Post#2726844
    In response to kingkreeton
Ant that the truth!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-08-18 08:24 PM - Post#2726944
Well I'm glad that's over with! Man it was more of a problem putting it all back together than getting it all a part!
I had to get my buddy to go back to his shop and get another set of spring compressor's so I could install the dang thing. I got everything buttoned up though. I even rotated the drivers side wheels.
All bolts are now grade 8 with nuts and lock thread on them. I greased all the fittings to.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
paintman
paintman
Loc: Smoky Mts., Tenn.
Reg: 02-27-12
03-09-18 01:31 PM - Post#2727030
Rich
1962 Chevy Impala Convertible 283 Auto
1964 Impala SS Coupe 327 250 Auto
2010 Mustang GT Convertible 5 speed
paintman
paintman
Reg: 02-27-12
03-09-18 01:32 PM - Post#2727031
    In response to paintman
Don't forget to get the front end aligned.
Rich
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-09-18 06:55 PM - Post#2727061
I went to 2 places today to get the front end aligned. Neither one could do it said the rear was to low to get the targets on and centered. I'll call Monday to the guys that did it when I had the wheels & tires installed.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-12-18 09:16 AM - Post#2727316
Called the place that I got the wheels & tires from. They have me down for 1pm Wednesday. That should get me to the beach before dark I hope since time changed!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
03-12-18 01:04 PM - Post#2727343
I hope your heater is working Andy. It's 43 degrees in MB right now with gusty winds and scattered rain. Pretty raw....and rude.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-12-18 01:10 PM - Post#2727344
    In response to 55Brodie
Yes it works fine! It's suppose to warm up by Friday. I'll be down late Wednesday night after work and front alignment. If you come out to the show look for me. I'll have water and chair to seat for awhile.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Execution time: 0.306 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:33 PM
