Username Post: 63 Impala Dash Bezel Adhesive        (Topic#349920)
ampico-kid
Reg: 07-12-17
03-03-18 03:31 PM - Post#2726331
What's the best kind of adhesive to use on a 63 Impala aluminum dash bezel? Since it may have to be removed at some point, it shouldn't be something that will make a permanent bond. Any ideas? Thanks.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
03-03-18 05:56 PM - Post#2726336
    In response to ampico-kid
Its held on by the switch nob bezels no glue necessary.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
junky
Loc: Northeast CT
Reg: 06-27-10
03-03-18 08:12 PM - Post#2726350
Rubber cement will do what you are requesting. As was said, they are held on mostly by the knobs, however, when new, GM did use a mastic on many of the dash bezels on the different lines of cars. Over time, the mastic dried up, and turned to powder. My guess is that it was more for keeping the part attached during the assembly process, till it got to the station where the next part was added that ultimately held the trim in place. A good example of this is the clips that hold the brake drums to the wheel studs, so the drums don't fall off during the assembly process. Usually they get taken off during the first brake inspection, and tossed, since the wheel now holds the brake drum on.
ampico-kid
Reg: 07-12-17
03-03-18 10:34 PM - Post#2726366
    In response to junky
I was thinking that possibly there was no adhesive used, but there was some white powerdery stuff behind the two panels when I removed them. The information supplied now makes sense. I'll take the advice and use some rubber cement to hold the panels in place and prevent any potential rattles. Thanks for the info.
junky
Loc: Northeast CT
Reg: 06-27-10
03-04-18 08:42 AM - Post#2726390
Just like Brylcreem, a little dab will do ya..
For those too young to know what it is....
http://www.youtube.com/watch?v=o6F4GtyRfto
03-04-18 03:03 PM - Post#2726419
WE USED THAT STUFF EVERY MORNING!!!
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
03-04-18 04:54 PM - Post#2726427
If it were me I'd use a very small dab of silicon. Rubber cement is nasty.
junky
Loc: Northeast CT
Reg: 06-27-10
03-04-18 08:18 PM - Post#2726447
    In response to Tri5man
What is nasty about rubber cement? Silicone on the other hand, is difficult to release once it sets.
Verne_Frantz
61-64 Subject Matter Expert
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
03-05-18 07:33 AM - Post#2726477
The originals that I've pulled off seemed to have a few daubs of what looked like light gray seam sealer. It never completely hardened.
Verne
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
03-05-18 07:35 AM - Post#2726478
    In response to Verne_Frantz
How about using some thin double face tape?
junky
Loc: Northeast CT
Reg: 06-27-10
03-06-18 03:27 PM - Post#2726676
    In response to turbo38s10
Problem with double sided tape, it can be difficult to remove in the future. This is why I recommended rubber cement. It holds the trim in place, and it is easy to remove in the future. It doesn't have an odor once it sets, and I can't see any down side to using it.
paintman
paintman
Loc: Smoky Mts., Tenn.
Reg: 02-27-12
03-06-18 03:44 PM - Post#2726679
Just use a few small strips of 3M Strip Caulk,no problem in future upon removal!
Rich
1962 Chevy Impala Convertible 283 Auto
1964 Impala SS Coupe 327 250 Auto
2010 Mustang GT Convertible 5 speed
junky
Loc: Northeast CT
Reg: 06-27-10
03-06-18 09:38 PM - Post#2726707
    In response to paintman
3M strip caulk isn't like it used to be. The last box that I got, was more like a permanent adhesive, than a caulk. I would liken it to a windshield butyl strip. This is the black caulk.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
03-07-18 06:56 AM - Post#2726730
tape is not difficult as long as you don't use molding tape by 3m. Us the thinner stuff like for carpet.
Execution time: 0.336 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:51 PM
