Username Post: air comp. ?        (Topic#349891)
Loc: kingman,az
Reg: 04-29-00
02-28-18 05:59 PM - Post#2726039
is there any advantage to a 2 stage comp. over a 2 cyl. one stage? [using the same motor]
thanks Rod in AZ
Reg: 12-29-02
02-28-18 06:05 PM - Post#2726040
    In response to rod
Wrong forum, but yes there is. A 2-stage will pump a higher volume of air. A 2-stage can also reach a higher pressure if you require a higher pressure.
Execution time: 0.273 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:54 AM
