Username Post: Tommy49's 1949 Deluxe Sport Coupe        (Topic#349880)
02-28-18 07:26 AM - Post#2725947
Attachment: P1010352.jpg (34.37 KB) 35 View(s)
02-28-18 09:44 AM - Post#2725975
Yummy!
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
03-01-18 06:52 AM - Post#2726086
Thanks, Ray, but I am embarrassed to say
that this is a rare picture with 4 wheels on the ground. I was hoping that I would have the body work done by now, but I don't. Trying to work with the old panels (say cheap) was an effort in futility, so I bought new quarters and a outer rocker and started over. Some of the work I had already down had/has to be redone. Lesson learned here and good thing I don't have a deadline.
Tommy
49 Deluxe Sport Coupe, 55 235, 700r4, Blazer rear axle, 4 wheel power disc brakes.
tommy49
tommy49
Reg: 09-28-12
03-01-18 07:10 AM - Post#2726088
    In response to tommy49
The wheel opening work shown has to be reworked because I did it to the old panels and the new panels aren't the same.
Attachment: new_quarter_panels_2.JPG (172.07 KB) 33 View(s)
Attachment: wheel_opening_reenforcement_1.JPG (161.61 KB) 31 View(s)
Attachment: wheel_opening_reenforcement_2.JPG (155.64 KB) 31 View(s)
Attachment: new_quarter_panels_3.JPG (176.41 KB) 32 View(s)
Tommy
Edited by tommy49 on 03-01-18 07:32 AM. Reason for edit: No reason given.
tommy49
tommy49
Reg: 09-28-12
03-01-18 07:51 AM - Post#2726092
The body mount was trashed. The PO's "repair" was bondo and window screen. Not much to work with. I made a fixture using some dimensions from the other side so I could make (say be cheap again) something usable. Here's the mount build in progress. The completed mount is temporarily in the car to set the inner and outer rockers up. I'll take that out, make any length changes if needed, then paint and weld in.
Attachment: P1030635.JPG (160.16 KB) 33 View(s)
Attachment: P1030636.JPG (162.8 KB) 32 View(s)
Attachment: P1030648.JPG (158.49 KB) 30 View(s)
Attachment: P1030650.JPG (163.41 KB) 32 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
03-01-18 11:34 AM - Post#2726123
Between honey-do's and the 49, I still find ways to get distracted.
I built a storage rack for my steel & aluminum supply. It started life as an airport baggage cart.
Then I finally did a speed reduction (pulleys & jack shaft) on my 1934 band saw so it would cut steel.
Attachment: storage_rack_for_steel_1.JPG (153.02 KB) 30 View(s)
Attachment: storage_rack_for_steel_2.JPG (159.63 KB) 32 View(s)
Attachment: 1934_power_king_band_saw_1.JPG (159.87 KB) 29 View(s)
Attachment: 1934_power_king_bandsaw_2.JPG (160.26 KB) 30 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
03-01-18 11:40 AM - Post#2726126
A few more of the shop stuff:
Some real jack stands. I got tired of wrestling the big wood blocks.
And 2 tool additions, a bead roller and rotary shear.
Attachment: real_jack_stands_1.JPG (159.65 KB) 31 View(s)
Attachment: real_jack_stands_2.JPG (160.58 KB) 31 View(s)
Attachment: woodward_fab___bead___flange_roller.JPG (157.56 KB) 31 View(s)
Attachment: rotary_shear_.JPG (165.06 KB) 33 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
03-05-18 05:16 PM - Post#2726550
Finally got the sheet metal fit and screwed in place.
Attachment: P1030676.JPG (156.96 KB) 31 View(s)
Attachment: P1030678.JPG (175.42 KB) 29 View(s)
Tommy
drock55
Loc: Caddo Oklahoma
Reg: 01-17-18
03-06-18 05:38 AM - Post#2726619
Nice looking work
tommy49
tommy49
Reg: 09-28-12
03-06-18 07:34 AM - Post#2726626
    In response to drock55
Thank you!
Tommy
EMS Customer Service
Thread Sponsor
Loc: cleveland, ohio
Reg: 04-18-10
03-10-18 03:23 AM - Post#2727091
thanks for buying from ems auto
the ems guy
tommy49
tommy49
Reg: 09-28-12
03-12-18 10:10 AM - Post#2727326
Since I have the quarter panel off today, I decided I would work at fitting the skirt. I made an oak form so I could shape the wheel opening profile to match the stock left side.
After a couple of adjustments to the form, the overall skirt fit was good, but the lower rear quarter/skirt fit was waaay off. I'll put the skirts back on the shelf until next winter.
Attachment: skirt_fitting_to_new_quarter_panel_5.JPG (158.36 KB) 28 View(s)
Attachment: skirt_fitting_to_new_quarter_panel_7a.JPG (172.18 KB) 26 View(s)
Attachment: skirt_fitting_to_new_quarter_panel_10.JPG (156.03 KB) 27 View(s)
Tommy
Edited by tommy49 on 03-12-18 03:56 PM. Reason for edit: No reason given.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
03-15-18 04:17 PM - Post#2727733
Hi Tommy, that's coming along nicely. I heard a rumor that the 49-50 skirt is slightly different from the 51-52 one in shape. Apparently there is only one shape in the aftermarket. Sorry I don't have an early one to compare.
Cheers Kiwi
tommy49
tommy49
Reg: 09-28-12
03-15-18 04:58 PM - Post#2727749
    In response to Bel Air kiwi
The skirts I have came with the car and had nice fit. They still have what looks like the factory undercoating/sound deadener. I found the new quarters aren't quite exact to factory, so I'll massage the skirts to fit.
Tommy
tommy49
tommy49
Reg: 09-28-12
03-24-18 11:57 AM - Post#2728786
I've been working on the inner wheelwell reenforcement & closeout pieces to stiffen up the quarter panels and seal up the wheelwells. I also wanted the rigidity for the skirts. Today, I burned up the afternoon making one of the pieces.
Attachment: wheel_well_reenforcement____closeout_1.JPG (155.3 KB) 20 View(s)
Attachment: wheel_well_reenforcement___closeout_2.JPG (156.57 KB) 20 View(s)
Attachment: wheel_well_reenforcement___closeout_3.JPG (155.79 KB) 19 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
03-27-18 05:45 PM - Post#2729149
Finally finished the wheelwell reenforcement! Now onward to the outer rocker panel details and put the weld holes in the inner rocker.
Attachment: wheelwell_reenforcement___closeout_4.JPG (158.21 KB) 20 View(s)
Attachment: wheelwell_reenforcement___closeout_5.JPG (158.41 KB) 19 View(s)
Tommy
Loc: Hendersonville, N.C.
03-31-18 05:05 PM - Post#2729530
Great work Tommy !
Our best to you and Kat.
1951 Styleline Deluxe 2 dr sedan. 1955 235" 3 speed std.
1969 Corvair 500 Coupe 28,000 miles.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
04-03-18 08:27 PM - Post#2729858
Hi Tommy
Sorry you had to redo all that work but I really like the look of the coupe.
Dean50
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-04-18 10:30 PM - Post#2729982
    In response to Dean50
^^^^^ I'll second that ^^^^^. Very nice work, and a very nice Coupe. I should have kept my 51 Bus Coupe; stupid, stupid, stupid! Keep posting. I am Butch/56sedandelivery.
tommy49
tommy49
Reg: 09-28-12
04-06-18 09:53 AM - Post#2730104
Thanks, guys! Things are moving along, but at a snails pace. I get hung up on the small stuff, and spend too much time fitting pieces. Kat says I'm too anal on stuff people won't see. The last couple days I've been slicing up the inner rocker because I don't like the gaps between the inner, outer rocker and the floor. On the brighter side, I did finish the body mount and it's ready to weld in, when the inner rocker's done.
Attachment: body_mount_floor_brace_right_side_8.JPG (156.74 KB) 12 View(s)
Attachment: body_mount_floor_brace_right_side_9.JPG (154.58 KB) 12 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
04-06-18 09:57 AM - Post#2730106
    In response to bobg1951chevy
  • bobg1951chevy Said:
Great work Tommy !
Bob! How are you & Bab's doing? How does Bab's like driving the 'vair? Did you sell the Chevy yet?
Tommy
tommy49
tommy49
Reg: 09-28-12
04-10-18 05:00 PM - Post#2730620
Today, I drilled the the plug weld holes in the inner rocker and finished the end piece for the floor brace.
Attachment: floor_brace_end.JPG (154.71 KB) 5 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
06-01-18 09:04 AM - Post#2735585
After a month break to reorganize the shop and other distractions, I finally got back to work on the 49.
The inner wheel opening and splash baffles:
Attachment: inner_wheel_opening_1.JPG (158.47 KB) 3 View(s)
Attachment: inner_wheel_opening_2.JPG (150.67 KB) 2 View(s)
Attachment: splash_baffle_1.JPG (154.92 KB) 2 View(s)
Attachment: splash_baffle_2.JPG (156.01 KB) 2 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
06-01-18 09:09 AM - Post#2735588
The inner rockers and braces:
Attachment: rockers_P1030775_door_opening_1.JPG (176.49 KB) 2 View(s)
Attachment: rockers_P1030777_door_opening_2.JPG (160.18 KB) 2 View(s)
Attachment: rockers_P1030778_door_opening_3.JPG (167.46 KB) 2 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
06-01-18 09:13 AM - Post#2735590
The inner rocker started off as a one piece part, but due to problems fitting the lower quarter, I cut it in half, just to make it easier to handle. The inner rocker also had it's share of fit issues.
Tommy
tommy49
tommy49
Reg: 09-28-12
06-01-18 09:21 AM - Post#2735594
The door opening and outer rocker are still in progress, but here's what I have at the moment. This will be done today and tomorrow, I'll start tacking in the both quarter panels.
Attachment: rockers_P1030779_door_opening_4.JPG (158.65 KB) 3 View(s)
Attachment: rockers_P1030780_door_opening_5.JPG (152.57 KB) 2 View(s)
Attachment: rockers_P1030782_door_opening_6.JPG (173.22 KB) 2 View(s)
Attachment: rockers_P1030784_door_opening_7.JPG (158.38 KB) 2 View(s)
Tommy
tommy49
tommy49
Reg: 09-28-12
06-01-18 09:40 AM - Post#2735597
My big problem was just getting the door to fit the body. It's not the original door, don't know what year, but it is for a coupe because it has "27" stamped on it. There are trim holes bondoed over, under the Deluxe trim. I had to elongate the hinge bolt holes on the "A" pillar, open the top of the hinge slots, and grind a relief in the hinge at the curve, so I could get the door/body gaps adjusted. This had to be done before I even thought about tacking the lower quarter and rocker in. It was very frustrating!
Tommy
Execution time: 0.393 seconds.   Total Queries: 28   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:59 AM
