Username Post: Will ATF hose work?        (Topic#349863)
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
02-26-18 08:59 PM - Post#2725771
I'm putting a new carb on. I need some 5/16" rubber hose. I dug around in the tool box and I found some unused rubber trans-cooler hose.
Will that work as a fuel line?
Edited by Stinky on 02-26-18 09:00 PM. Reason for edit: No reason given.
02-27-18 07:32 AM - Post#2725813
    In response to Stinky
Temporary only.
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
02-27-18 03:27 PM - Post#2725860
Thanks, I was thinking about it...for 3 bucks I can get the right hose and not worry about it leaking and then burning to the ground.
02-28-18 09:10 AM - Post#2725966
I was going to suggest that.
02-28-18 09:23 AM - Post#2725970
Leaking would not be the problem with low pressure hose. Rubber bits flaking off the inside of the hose from the alcohol will cause problems in the carb.
Execution time: 0.316 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:43 PM
