Username Post: Brakes on 1967 rs        (Topic#349839)
sprog777
Reg: 03-27-10
02-26-18 01:21 PM - Post#2725690
Just bought a Camaro 1st gen. I have done a lot of brake work on cars but this one has me stumped. The brake pedal hardly moves at all when applied and dosen't stop all that well. It has after market disc on the front and drums on rear.I'm wondering where to start. I know that power brakes use a differnt hole on the brake pedal. This is a manual brake car so which hole should the plunger be hooked upper or lower.And if anyone has any ideas so I don't go part swapping I would be open to suggestions.
sprog777@yahoo.com
1979 K5 Blazer
2001 1500 z71 ext.cab
1999 Chevy Tahoe 4wd
1999 chevy z71 ext.cab
1966 Mustang coupe
1967 rs Camaro
1992 Mazda Miata
2009 ultra classic electra glide
1986 Gli
models916
Loc: Addison, IL
Reg: 05-28-10
02-27-18 06:18 AM - Post#2725806
    In response to sprog777
Disc.drum combo requires a different master and proportioning valve to operate correctly. 1968 Chevelle non power master for disc is a good option.
sprog777
Reg: 03-27-10
02-28-18 08:03 AM - Post#2725958
    In response to models916
That would be and easy place to start. Car is new to me and I really don't know what po changed that or not. Thanks for the reply
sprog777@yahoo.com
1979 K5 Blazer
1966 Mustang coupe
1967 rs Camaro
1992 Mazda Miata
1986 Gli
J C
Loc: Orange Co. Calif
Reg: 04-17-04
03-05-18 09:14 AM - Post#2726496
I had a similar problem on my 69. I got a rebuild kit that had the wrong parts in it. Turned out to be a wrong rear gizmo in the master cyl. The rod that went into it did not allow for any movement. When I got the correct gizmo with a deeper hole everything worked fine. This is probably not your problem but I thought I would throw it out there.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
6T5
Infrequent Contributer
Loc: Asheville, NC
Reg: 07-22-17
03-06-18 05:04 AM - Post#2726616
    In response to J C
I would think a proportioning valve would be inline at the master cylinder even if it's not power brakes and if so it's possible that the valve (inside the proportioning valve) is not centered allowing correct pressure to both front and rear. Also have you tried to re-bleed the system and check for good bleeding flow and no air in the lines?
6T5
Loc: Asheville, NC
Reg: 07-22-17
03-18-18 03:58 AM - Post#2728014
    In response to 6T5
Hey sprog777 it's been awhile, do you have any update, curious minds want to know...Ed
sprog777
Reg: 03-27-10
03-23-18 07:28 AM - Post#2728645
    In response to 6T5
well I am working on three different projects right now and my truck is going to be daily so it getting most of my time right now.
sprog777@yahoo.com
1979 K5 Blazer
1966 Mustang coupe
1967 rs Camaro
1992 Mazda Miata
1986 Gli
Execution time: 0.233 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:25 AM
