Username Post: Buying Used 2008 Suburban LTZ        (Topic#349804)
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
02-24-18 12:35 PM - Post#2725445
Anything to avoid in these years?
My 2000 is all worn out. Looking for a southern vehicle.
82 Monte Carlo SC, 355 w/Vortec heads, roller rockers, 670 Street Avenger, TRUE DUALS.
2009 Sub.5.3L LTZ 30 Gallons of gas @ $2.49/gal. bla bla bla.
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
02-27-18 07:20 AM - Post#2725812
    In response to black95jimmy
OK, guess they are all good.
elcamino
elcamino
Reg: 03-30-00
02-28-18 05:09 AM - Post#2725935
Any 10 yo vehicle with high miles is always a risk. The early models with Active Fuel Management (AFM) had oil burning issues, some were ok and some were not so its a crap shoot. Carbon buildup on pistons can cause the piston rings to stick in their grooves. Stuck rings can fail to seal the combustion chamber, leading to oil consumption and low compression, negatively affecting engine performance. Excess piston deposits can also lead to pre-ignition and engine knocking, which results in lost power, reduced fuel economy and, in severe cases, engine damage. This problem can manifest with as little as 30,000 miles.
IMO you would be better of with a Yukon Denali XL with the 6.2L engine (standard on Denali's) as those 6.2L engine do not seem to suffer from oil consumption like the 5.3L does. But the 6.2L coupled with standard Denali All Wheel Drive are going to return lower mpg (premium fuel req'd), typically about 1-2 mpg less with 380 hp vs. 5.3L 310 hp. The 6.2L also has AFM in suvs.
Active Fuel Management (formerly known as displacement on demand (DoD)) is a trademarked name for the automobile variable displacement technology from General Motors. It allows a V6 or V8 engine to "turn off" half of the cylinders under light-load conditions to improve fuel economy.
2016 Polaris RZR 900 EPS
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
03-07-18 06:52 AM - Post#2726727
    In response to elcamino
Thanks , looked a Danali, premium fuel was a turn off.
Looking at an 09 LTZ this weekend, 137k.
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
03-08-18 07:47 AM - Post#2726854
My current suburban has torsion bars, what did they do on the newer models?
elcamino
elcamino
Reg: 03-30-00
03-09-18 05:56 AM - Post#2726971
Don't know, have not looked them, Drive a 4wd truck. Winter up her from Nov to Apr so 4wd is popular. Hard pressure to find 2wd trucks around here, no one wants one.
Ps- my 2017 Sierra Denali 4wd 6.2L with 8-sp trans averages 19.7 mpg (and I use AUTO 4wd a lot in winter), about 23+ on the hwy if I stay 70 or less which is no problem, mostly 2 lane blacktop around here. My last work 'burban (GPS Survey Team), K3500 special fleet with 350 and 4.11 rear axle got 10 mpg best. That SUB was tough, 125,000+ miles and only needed brakes once.
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
03-11-18 01:38 PM - Post#2727218
Got the 2009 yesterday.
Matt
Matt
Loc: SAV
Reg: 09-26-01
03-11-18 08:28 PM - Post#2727250
Good to hear! Now lets see some pics!
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
03-15-18 02:25 PM - Post#2727723
    In response to Matt
Execution time: 1.355 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:46 AM
