Username Post: BBC 7/16ths.rod bolts        (Topic#349786)
Am4wag
Reg: 11-19-15
02-23-18 10:10 AM - Post#2725334
Well as another post of mine indicates,I had to replace the 454 Gen.VI block on my build.The rods and crank are stock forged from a 502,and have been balanced.Beings the nuts have been on/off 3-4 times,I'm thinking maybe changing the rod bolts and nuts with ARP's while waiting for my block from the m/s.Would I need to rebalance the rotating assy. if so?
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
Edited by Am4wag on 02-23-18 10:11 AM. Reason for edit: No reason given.
02-23-18 02:59 PM - Post#2725363
    In response to Am4wag
If you change the rod bolts, the big end of the rods will need resizing, std procedure when the bolts are changed.
models916
Loc: Addison, IL
Reg: 05-28-10
02-26-18 05:25 AM - Post#2725641
And rebalanced.
Execution time: 0.608 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:42 PM
