Username Post: 78 Regal steering column        (Topic#349756)
78elk
Reg: 12-23-08
02-21-18 07:21 AM - Post#2725088
I have 2 78 Buick Regal steering columns that are tilt with cruise. Each one has an issue. 1 has an actuator issue and the other has a loose tilt problem. I have removed the steering wheel and screws from the turn signal switch & lever. Still can't get the turn signal lever out. This lever also is the dimmer switch. What's the secret to removing this lever?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
02-22-18 05:19 PM - Post#2725270
    In response to 78elk
Pull harder, it has a tight fit. No tool necessary.
78elk
Reg: 12-23-08
02-22-18 07:38 PM - Post#2725280
    In response to junkman104
Thanks. How hard is it to change the bearing in the top of the column?
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
02-22-18 10:32 PM - Post#2725293
Not terribly difficult if you have a steering wheel lock plate puller. There's a wire lock ring that sits kinda close to the bearing. You'll want the puller to do the lifting on the shaft. Take a couple pieces of steel stock and lay them across the steering hub. This gives you something to push against to lift the steering shaft.
Attachment: th.jpg (2.8 KB) 20 View(s)
Greg
'00 Explorer XLT 4.0 V6 Auto
78elk
Reg: 12-23-08
02-23-18 04:40 PM - Post#2725368
Thanks, I have that tool and use it. What do you use to pull the old bearing out with? What do you do to keep the new bearing from falling apart as you install it?
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
02-23-18 10:38 PM - Post#2725399
I’m afraid I’m not much help beyond getting the clip out.
Greg
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
02-24-18 05:37 AM - Post#2725407
    In response to CowboyTrukr
If your column is loose the chances of a top bearing fixing it is slim. The most common problem is the 4 bolts that hold part 174 to the mast get loose. The entire column has to be disassembled to get to them. I have repaired many of them.
http://repairguide.autozone.com/znetrgs/repair_gui...
78elk
Reg: 12-23-08
02-24-18 08:14 AM - Post#2725420
Thanks. The very top of the shaft was loose. I found a piece that looks like it should be next to the bearing. I also found metal dome with a hole the same size as the steering column shaft. When I put those pieces on the column, the slop disappeared. I'm not saying that it's fixed. I'm thinking that this top bearing probably needs to be replaced.
78elk
Reg: 12-23-08
03-04-18 12:05 PM - Post#2726410
I'm having a problem with the horn, turn signals, a 4 way flashers aren't working. Fuses are fine. What could I have missed that's causing this issue?
78elk
Reg: 12-23-08
03-05-18 12:03 PM - Post#2726517
I finally figured it out. One end of the column wire harness wasn't able to connect. After I played with it, all is good and functioning properly.
