Username Post: Oil        (Topic#349690)
ejw71
Loc: Bella Vista, AR
Reg: 01-19-01
02-16-18 10:17 AM - Post#2724591
My 350, 10,000 miles, runs 10w30 oil. Can I now replace it with synectic oil? Tks, Ed
65_Impala
Reg: 12-29-02
02-16-18 10:47 AM - Post#2724597
    In response to ejw71
Yes, you can change back and forth whenever you want.
IgnitionMan
Reg: 04-15-05
02-16-18 03:40 PM - Post#2724621
From my hands on experience, NO, stick with the oil you started with.
It really comes down to the design of the components that are used within the engine, year it was manufactured. Later engines with hydraulic roller cams and induction hardened crank throws, better bearings, can use synthetics, earlier engines made with older metals, gaskets, NOT recommended.
When the engine starts to leak oil from all the gaskets after switching to synthetics, you will know for sure you shouldn't have.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
02-16-18 05:21 PM - Post#2724627
    In response to IgnitionMan
i'm with ignition man. stick with conventional oil.
i change mine every 2000 miles,regardless of time and never have had a problem in 40+ years.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
14 camaro (new)
Execution time: 0.315 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:34 PM
