Username Post: Install weather strips on doors        (Topic#349663)
Larry E
Loc: Los Angeles
Reg: 09-15-16
02-14-18 11:12 AM - Post#2724388
Does anyone have any tips or instructions on installing weather strips on doors and trunk. I am redoing a 1950 Styleline and not sure which side should be glued down.
Larry E
Loc: Los Angeles
Reg: 09-15-16
02-14-18 11:13 AM - Post#2724389
    In response to Larry E
Tried to post pics I have on flicker but not sure how to get them on here. I am on a mac.
02-14-18 11:26 AM - Post#2724390
Posting pictures
Sheldon Y.
Loc: Waltham, Massachusetts
Reg: 10-29-16
02-14-18 03:31 PM - Post#2724416
Just finished doing mine.
The Filling Station has good Trunk Instructions in their Tech Help Section. (I almost put the 2-pcs. on wrong!)
For the Doors, I gave up with the repop originals and went with regular c-shaped door weatherstrip like you find on the Advance Design trucks.
'49 Styleline Deluxe Build@
https://www.jalopyjournal.com/forum/threads/49-sty...
http://www.frankenrodz.com/frankenstyle.html
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
02-14-18 06:32 PM - Post#2724438
50sChevys
Loc: Central Texas
The key to successful use of 3M Black Super Weatherstrip and Gasket Adhesive no. 08008, is to consistently follow the directions for application. Biggest failure is not applying a thin consistant coat to Both surfaces and allowing Enough Time to elapse before compressing them together. Used it successfully for longer than I like to remember...lol.
Regarding the trunk lid and the body....the seal is in two pieces and goes like the picture below. The other piece of course goes on the body.
http://pic100.picturetrail.com/VOL424/525201/24517...
50s Chevys
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
02-14-18 08:21 PM - Post#2724442
The door weatherstrip is pretty straignt forward as to orientation. The image below is from the 1953 Chevrolet Engineering Booklet. The original illusrtation showed a comparison between the profile of the 1952 [49-52] weatherstrip as compared to the new 1953 door weatherstrip profile [not shown].
The image below shows what is available for the trunk body weatherstrip and the trunk lid weatherstrip [Steele Rubber Illustration]. Steele also sells the corner pieces as was used originally, a soild body weatherstrip is also available if you wish to not go back to what was done originally.
Lastly two illustrations of the proper orientation of the trunk weatherstrip; the trunk body weatherstrip and blow that both body and lid profiles. You can see its profile matches closely to what is available. It is a good idea to mark the center of the weatherstrip and match it to the center of the car. The body strip will be a little more difficult with the lid attached to the car as you will need to work around the hinges. As stated...follow the directions closely. You are working with contact cement and you only get one shot at getting the weatherstrip where it needs to be.
1951 Fleetline
2blu52
2blu52
Reg: 03-12-02
02-15-18 05:35 AM - Post#2724456
    In response to 50sChevys
Agreed! I did my doors on the 52 about 15 years ago, used 3-M cement according to instructions and with one small are had trouble keeping the stripping tight. That was on a corner at the bottom of the driver door. Jacked the car up, got on my back, cleaned the area properly and reset the weather strip and no more problems.
THOMAS JEFFERSON
Larry E
Loc: Los Angeles
Reg: 09-15-16
02-15-18 07:49 AM - Post#2724464
Keith,
These instructions for posting pics is for a pc. I can't get the same info on my mac. I will try and figure it out.
Larry E
Loc: Los Angeles
Reg: 09-15-16
02-15-18 07:50 AM - Post#2724465
    In response to 2blu52
Hey guys,
Thanks for all of these pics pics and info. Very helpful.
I will try to install this weekend.
02-15-18 09:57 AM - Post#2724482
Take a look at the overall forum,which is at the top and see if Tony addressed a Mac.
50_Fastback
50_Fastback
Loc: California Central Coast
Reg: 09-08-14
02-15-18 07:06 PM - Post#2724535
    In response to Sheldon Y.
Sheldon,
Do you have a link or contact info for your source of C shaped door weather stripping?
Ron Starkey
Life's full of risks..........take one!
'50 Fleetline 350 SBC, TH350 Tranny, Nova Rear end, Mustang II clip
2005 Harley Road Glide
Sheldon Y.
Reg: 10-29-16
02-15-18 07:15 PM - Post#2724537
    In response to 50_Fastback
Perfectfit.com
800.652.5202
I use #AV16390 Door Weatherstrip - early GM, Ford, Chrysler.
$18./15 foot
Been using it for years on all my builds, with the 3M Weatherstrip Adhesive as mentioned.
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
02-16-18 07:15 AM - Post#2724570
This might help you Larry. The quality from Steele is your best bet and it doesn’t come from China... I’ve tried them all over 25 years and 10 frame offs...
Attachment: 08A1EAF8-E64B-4D1E-A0EF-9BA47C07D2B0.jpeg (2.05 MB) 3 View(s)
50s Chevys
Larry E
Loc: Los Angeles
Reg: 09-15-16
02-16-18 10:16 AM - Post#2724599
Thanks for all of the info guys. My first restore.
Hopefully I can get to it this weekend.
Execution time: 0.194 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:20 PM
