Username Post: 4WD TAHOE 4L60E interchangeable years.        (Topic#349659)
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
02-14-18 10:46 AM - Post#2724371
Will a 2005 Blazer trans directly swap into a 1996 Tahoe without any wiring harness compatibility issues?
Thanks.
Nitrous is like a hot girl with STD's…You know you wanna hit it, but you’re afraid of the consequences!
1965 Biscayne 2 Door Post: 350,PG,373-posi,C3-DB, PS,PB.
1970 Chevelle Malibu: 53 on 753.
Brian Daniel McClure: 1970-2015. R.I.P. Brother.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
02-14-18 06:07 PM - Post#2724428
    In response to BowtieGent
Nope, 6 cyl input has a 298mm length small spline and V8 has a 300mm 30 spline. Nothing but problems there. Internals are the same "kinda" I just rebuilt a burned up 05 suburban with a 05 Colorado core. Everything was the same but the input aka front drum. The pump and case is 05 up also.
02-14-18 06:14 PM - Post#2724431
    In response to junkman104
Another catch is the 1996 is still one-piece case. Mid-1997 they went to two piece which also changed the adapter to the transfer case, so if you use a newer trans, you also need that piece.
But even if everything else was equal I would not bet on the 1996 and 2005 being the same electrically.
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
02-16-18 09:40 AM - Post#2724586
    In response to someotherguy
Ok, I see. I was expecting to hear that there were/are differences.
How about a 4L60E from a '99 Tahoe into the '96 Tahoe?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
02-17-18 05:36 AM - Post#2724658
It will fit, the number one difference will be 98 and newer two piece case has a tail housing Held on with 6 bolts. The 97 and earlier is a 4 bolt type. You never stated if yours is a 4wd or 2wd.
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
02-20-18 11:44 AM - Post#2724993
4WD, Stated in thread title.
No issues with the '99 computer communicating with the '96 transmission then?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
02-22-18 05:21 AM - Post#2725168
Wiring is the same 1993-2002
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
02-22-18 11:26 AM - Post#2725219
Execution time: 0.344 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:03 PM
