Username Post: Alternator output wire        (Topic#349655)
Big T
"12th Year" Silver Supporting Membe
Big T
Loc: Simi Valley CA
Reg: 04-14-06
02-13-18 11:34 PM - Post#2724332
Hi All
Been awhile. I am back on the 55.
Have a question. I have a SI12 alternator 98 Amps as I recall.
The charging system is finished, but I am now being told by Painless tech(bought their latch up disconnect for an additional layer of theft protection) that the 8AWG (stranded) alternator output wire I am using, is under rated because my bat is in the trunk and suggested I change it out for a 6AWG "cable".
6awg stranded cable "by the foot" is impossible to locate.
On top of that, that ckt has been in for a long time so now there are plenty obstructions added along its route.
The distance from alternator to the battery via the disconnect is roughly 12 feet. The 8awg passes through two single point terminal blocks on the way back to B+.
I wanted to check in with you for your thoughts and comments. If I have to do it, I have to do it.
Thanks in advance
Tom
Tom
55 4 door BelAir
02-14-18 05:56 AM - Post#2724347
    In response to Big T
Do you have a lot of high draw accessories in the circuit?
02-14-18 07:18 AM - Post#2724352
I think your fine with 8 gauge. You will never use the full 98 amps of the alternator unless the battery was completely dead and then you couldn't start the car to use the alternator.
02-14-18 08:12 AM - Post#2724356
Pay a visit to your local home improvement store or electrical contractor supply outfit. Ask for 6 ga copper building wire by the foot. The stranding is different from automotive wire, so it is somewhat stiffer, but it will still work very well for your intended purpose. Make sure to specify copper, because it is also made in copper coated aluminum and you don't want that type.
I have been using this product on vehicles for many years with no complaints. Also, it is notably less expensive than automotive or welding cable of the same gauge.
Big T
Big T
Loc: Simi Valley CA
Reg: 04-14-06
02-14-18 10:49 AM - Post#2724383
I have is two large puller Spal fans (w/controller), classic auto A/C w/trinary, Aftermarket radio....using as is out of the box, 60x4 watts internal amp using only 2 6x9 speakers in the package deck, after market cruise control....not seeing that as being used very often, Dakota Digital dash...low power, all LED lights inside and out, using several relays to cut down on power going through the dash/switches.
At one time, I was thinking about using H4 head lights. But, looking into the newer LED hi/low head lights it's starting to look like a better choice. Bonus....less power
I live just outside of Los Angeles County with it's 10.2 million people. Lots of ambient light for night driving.
A couple of other things are low amp, intermittent use. Not planning on anything more.
Tom
Tom
55 4 door BelAir
PhilG
Reg: 04-04-06
02-14-18 01:27 PM - Post#2724400
Hey Tom
Check out https://www.wireandcableyourway.com/cart.php?m=vie...
SGT ( starter-ground thermal coating )copper wire @ .58/foot min 20 ft. US made
Big T
Big T
Loc: Simi Valley CA
Reg: 04-14-06
02-14-18 01:50 PM - Post#2724402
    In response to PhilG
will do Phil
Thanks Tom
Tom
55 4 door BelAir
02-14-18 02:22 PM - Post#2724407
Do not use house wiring in your car. The insulation won't last very long at all. House wire is not made for heat or oil.
If I picture your wiring correctly, the battery is the only thing running off the full length of this wire. I'm thinking everything else is running off the terminal blocks. Is that correct? If so, the full length will never see the full amps of the alternator.
Bluemeany
Bluemeany
Loc: Santa Clara, CA
Reg: 05-31-02
02-14-18 03:04 PM - Post#2724412
Your battery is in the trunk and I assume you have the big positive cable going to the starter solenoid. You could run the 8AWG alternator wire to the same solenoid post.
57 Hardtop 302 & 3 Speed stick w/OD;
93 Camaro Indy Pace Car
02-14-18 05:08 PM - Post#2724429
    In response to Bluemeany
Yeh, that is how I am set up. Seems that would solve the wire size and routing.
Big T
Big T
Loc: Simi Valley CA
Reg: 04-14-06
02-14-18 05:36 PM - Post#2724435
    In response to acardon
Hi Don
Spot on. Alternator runs everything in the car on its way to the battery
Tom
Tom
55 4 door BelAir
02-15-18 02:08 AM - Post#2724449
  • acardon Said:
Do not use house wiring in your car. The insulation won't last very long at all. House wire is not made for heat or oil.....
I agree that the older types of building wire might not be the best choice for use on a motor vehicle. However, the present type is THHN, which has an extremely tough nylon outer layer that is heat, oil, and abrasion resistant. I have never had any insulation failures with this type, even when installed in direct contact with the engine.
Execution time: 0.203 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:20 PM
