Username Post: '69 Impala front suspension rebuild kit        (Topic#349648)
Carolina Dreamin
Loc: Albany, NY
Reg: 01-16-17
02-13-18 04:43 PM - Post#2724295
I want to rebuild the entire front end of my '69 Impala. Can someone recommend a kit? Thanks
Custom670
Custom670
Reg: 09-01-12
02-14-18 09:46 AM - Post#2724361
    In response to Carolina Dreamin
I used a kit from Performance Suspension Technology when I rebuilt my 1970. Everything fit right in and no problems with it.
https://p-s-t.com/
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
02-14-18 09:52 AM - Post#2724363
    In response to Custom670
"Rebuild the front end" can mean a lot of things. From just new bushings & ball joints to new tubular control arms & coil overs. That's just too open ended of a question.
Carolina Dreamin
Loc: Albany, NY
Reg: 01-16-17
02-14-18 11:39 AM - Post#2724380
    In response to sz0k30
Sorry, just a stock front end rebuild, bushings, tie-rods,ball joints, etc. PST was one of the vendors I wanted to know about, thanks.
Custom670
Custom670
Reg: 09-01-12
02-14-18 10:03 PM - Post#2724444
Not really, I knew what he meant. The majority of people I speak to, when discussing front end work, refer to replacing worn out parts like bushings and ball joints as "rebuilding". When they want new control arms or or sway bars they invariably refer to it as "upgrade" or "modernize".
sz0k30
sz0k30
Reg: 10-12-08
02-15-18 08:16 AM - Post#2724461
  • Custom670 Said:
  • sz0k30 Said:
"I knew what he meant.
Good for you.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
02-15-18 09:34 AM - Post#2724472
I'd try to stick with name-brand parts, such as Moog. And use quality rubber parts.
I don't know if these "kits" contain name brand parts. I know PST has been around a long time, and Custom670 says, you'll have no problems.
For a higher quality rebuild using parts such as Moog, I think you'd have to piece parts separately to for a full rebuild. It will be more expensive and time consuming, but worth it, IMO.
Edited by BigDogSS on 02-15-18 09:46 AM. Reason for edit: No reason given.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
02-15-18 04:37 PM - Post#2724504
    In response to BigDogSS
I normally buy the parts piece-by-piece as BigDog stated. Recently I bought parts by "Proforged". They offer what seem to be high quality parts and the ones I purchased were even e-coated. I don't know for certain what they offer for the Impalas but the parts for my daily driver were quite impressive.
One other thing which I guess is obvious. With these cars do not assume you can buy everything new. Suspension parts are available but even regarding the suspension there were very few choices I found for the center link.
When I consider bushings I avoid polyurethane because under constant load it will cold form; meaning permanently deform.
Scott
69 RAG
69 RAG
Loc: Newfoundland
Reg: 02-19-16
02-15-18 06:01 PM - Post#2724515
    In response to toro455
Hi guys . I rebuilt my 69 front and rear suspensions and found i had to get pieces from all over. Glad i did it. Cant wait for summer good luck jim
Execution time: 1.131 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:17 PM
