Username Post: 409 car or not?        (Topic#349642)
Carl1962
Carl1962
Loc: Bungendore Australia
Reg: 04-01-10
02-13-18 11:50 AM - Post#2724271
A friend of mine has found a car he is told used to be a 409 car. The engine is long gone but the other clues appear to be there. The dual fuel lines, fuel sender and ballast resistor.
Attachment: 3.jpg (105.96 KB) 21 View(s)
Attachment: 1.jpg (132.01 KB) 8 View(s)
Attachment: 2.jpg (142.4 KB) 3 View(s)
Cheers, Carl.
1962 SS Impala Sports Coupe
http://s465.photobucket.com/albums/rr18/1956Carlo s...
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
02-13-18 06:08 PM - Post#2724304
    In response to Carl1962
Where built? trim tag pic? Tach and what is the rpm of it ? Fuel line I assume goes under control arm? Holes in fenders for "409"?
Member #2194
Brian64SS
Brian64SS
Loc: Milwaukee, Wi
Reg: 09-30-00
02-13-18 06:31 PM - Post#2724307
    In response to DonSSDD
Looks good (and familiar). The hole directly below the ballast resistor is where a connector goes to wiring for the back-up light switch mounted to the shifter of a Muncie 4-speed.
Brian
1964 Impala SS, 283 (not original), 4-speed (25 years)
1964 Impala 4-door hardtop, 283 Powerglide (2 years)
They made a million but I only have two.
Verne_Frantz
61-64 Subject Matter Expert
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
02-13-18 07:25 PM - Post#2724312
    In response to Brian64SS
The original return line is there. The firewall indications are not there. Probably a real 409.
Verne
Edited by Verne_Frantz on 02-13-18 07:31 PM. Reason for edit: No reason given.
Carl1962
Carl1962
Reg: 04-01-10
02-13-18 10:35 PM - Post#2724329
    In response to Verne_Frantz
Thanks gents, the cowl tag for this car is inconclusive when it comes to the codes for a 4-speed as my research indicates that other plants used codes for 4-speed or powerglide, but St Louis only used codes that relate to long or short console for an SS, not transmission.
The guards had the holes where the 409 badge would be, but the dash is gone. I haven't seen a floor photo.
Attachment: 27752106_1559951434054127_1381053039839846052_n.jpg (208.35 KB) 8 View(s)
Cheers, Carl.
Brian64SS
Brian64SS
Loc: Milwaukee, Wi
Reg: 09-30-00
02-14-18 04:42 AM - Post#2724338
I should have stated the back-up light switch mounts to a bracket that attaches with two of the side cover bolts. It has linkage to the shifter but doesn't exactly mount to the shifter.
Based on the frame alone, I was going to guess it's a St. Louis car
By the way, is this Australia, being a left hand drive car?
Brian
Edited by Brian64SS on 02-14-18 04:46 AM. Reason for edit: No reason given.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
02-14-18 09:20 AM - Post#2724368
Muncie in a 64? I thought they came out in late 65, and early 66.
Shouldn't a 64 have a Borg-Warner T-10?
I may be mis-remembering. After all, I am old.
Griff
if you're gonna be a bear.............
threeimpalas
Loc: Central Iowa
Reg: 02-21-02
02-14-18 09:51 AM - Post#2724373
    In response to beagrizzly
The Muncie 4-speed was introduced during the '63 production.
'58-62s and 348/409s
Edited by threeimpalas on 02-14-18 09:51 AM. Reason for edit: No reason given.
02-14-18 09:58 AM - Post#2724374
Griff
The B-W T-10 was replaced by the Muncie in mid-63 production ----------------- about Feb 63.
The 63 Muncie (1/2yr) was sort of a unique, one of a kind Muncie. Some people consider the 63 Muncie a weak 4spd -------------------- It is not! Although, it did have some very unique features, it was a good transmission, and when properly rebuilt by a VERY KNOWLEDGEABLE rebuilder, it is just fine.
Thus, the ONLY 4sp in mid-63 to early 70s full size Chevys was the Muncie.
In 66, SOME low-perf GM cars got the cast iron Saginaw (NOT used behind hi-perf engines), and in 75, the Muncie was replaced by the B-W SUPER T-10.
Carl1962
Carl1962
Reg: 04-01-10
02-14-18 11:42 AM - Post#2724391
The car is in the US, the fellow asking questions is a friend on facebook. Thanks to everyone for all the help.
Cheers, Carl.
Brian64SS
Brian64SS
Loc: Milwaukee, Wi
Reg: 09-30-00
02-14-18 04:01 PM - Post#2724419
I was assuming it's a '64, but it's obviously a '63 so might not be a Muncie based on DZAUTO's reply. It looks to be a first week of February car so right around that cut-off date for T-10/Muncie. My '64 has a 10-spline output shaft where this one also obviously has more. Maybe the driveshaft is from a different car with a PowerGlide or the hole wasn't for back-up light switch wiring.
Keep us up to date on what your friend decides to do with it.
Brian
Execution time: 0.231 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:13 PM
