 Page 2 of 2 <12
Username Post: Check out what Steve65 and I did to his beloved Annie...        (Topic#349637)
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
03-05-18 04:03 PM - Post#2726542
    In response to BowtieGent
So, Here we go again. This time on the Drivers side of the trunk.
Captured Steve in a really cool action shot.
Attachment: 20180304_144216b.jpg (920.4 KB) 9 View(s)
Trunk drop-off was also removed and is pretty beat up. Photo to follow soon.
Attachment: 20180304_135040b.jpg (1 MB) 5 View(s)
Not afraid to get after it.
Nitrous is like a hot girl with STD's…You know you wanna hit it, but you’re afraid of the consequences!
1965 Biscayne 2 Door Post: 350,PG,373-posi,C3-DB, PS,PB.
1970 Chevelle Malibu: 53 on 753.
Brian Daniel McClure: 1970-2015. R.I.P. Brother.
66cayne
Reg: 08-06-08
03-08-18 06:38 PM - Post#2726930
Is that a quarter panel patch-panel I see in the photo? It appears to be tacked from the inside of the panel. Sure wish I could weld. Carry on.
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
03-09-18 07:51 AM - Post#2726980
    In response to 66cayne
Yes, that's a patch from an old impala door that I took off. Lorne is using the door skin for patches, original Chevy steel. We may be getting our hands on some original inner/outer fender wells as well. As you guys know there are no repo convertible fender wells out there.
Steve65
Steve Duncan
65 Impala SS Convertible
Ermine White/ Black Top
357 4 spd auto
www.picturetrail.com/steved65
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
03-09-18 11:15 AM - Post#2727011
Yes, It's a patch from an old door, but is tack-welded from the outside.
I wish I could weld too...
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
03-09-18 11:17 AM - Post#2727012
    In response to steve65
Steve65
They will likely be ready for shipping (from sunny California) this weekend.
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
03-14-18 09:41 AM - Post#2727577
More new steel, body mount bushings, trunk weatherstripping and wiring harnesses arrived yesterday.
Attachment: 20180313_155051.jpg (904.04 KB) 3 View(s)
Attachment: 20180313_155111.jpg (845.65 KB) 3 View(s)
66SS632
Loc: Langley BC
Reg: 02-09-13
03-14-18 10:34 AM - Post#2727587
Good job so far!
I'd rather do all the frame stuff than tackle rusty sheet metal lol!
That body mount kit looks EXACTLY like the one I just got. If it is all the frame holes are too small!
One size is 1.437 and the other is 1.531 for the rubber bushings.
Body mount holes are roughly1.200 and 1.375. So they will all need 1/8 ground out if your situation is the same as mine.
I MIGHT try machining down the body mount rubbers to fit the holes. If that works I'll let you know. I could do your set also...
Happy happy happy
Still a 17 year old delinquent Hot Rodder
jktucker92
jktucker92
Reg: 02-05-17
03-14-18 12:30 PM - Post#2727597
    In response to 66SS632
I had the same problem with the bushings for my '66. I used a hole saw that had the right inside diameter (1.2" and 1.375" ID). I made a pilot bushing out of aluminum that fit in the hole saw where the drill bit would usually go that was a snug fit to the bushing metal sleeve. Then just ran the hole saw down 1/8" and used a box knife to trim it off from the outside. The process worked great.
66SS632
Loc: Langley BC
Reg: 02-09-13
03-14-18 12:55 PM - Post#2727600
    In response to jktucker92
Funny you should mention that lol! I just bought the hole saws to try that first ( because my frame is currently off the body) but I haven't had a chance to get at it .
Machining or grinding rubber is a bit of a trial and error deal. Steve and Lorne will probably face the same problem if they are going to replace all the body bushings.
To get at the holes they will have to take the body off. Are you guys planning on doing that?
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
03-14-18 03:55 PM - Post#2727612
  • 66SS632 Said:
Good job so far!
Removing the rust is easy enough, just messy as all hell. Like peeling back an onion. Once all the rusted areas are removed, replacing with fresh metal is pretty easy. AND, it's instant gratification.
The incredibly frustrating part is sheetmetal that doesn't line up correctly or has to be heavily modified to work.
Happy happy happy
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
03-14-18 04:03 PM - Post#2727615
At this stage/point in the restoration, we will just be replacing the body mount bushings for the trunk area.
Steve has a line on a replacement frame. If he happens to purchase it, then we will replace the remaining body mount bushings for the rest of the car after the frame has been cleaned up and painted.
At that point, we will likely take some rubber off the bushings as opposed to boring out the holes in the frame.
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
03-14-18 04:04 PM - Post#2727617
  • 66SS632 Said:
Good job so far!
Happy happy happy
jktucker92
jktucker92
Reg: 02-05-17
03-14-18 07:00 PM - Post#2727640
Here's some photos of how I cut down the bushings. it actually went really well. I've seen others widen the holes in their frame and I just couldn't bring myself to modify the frame to fit an aftermarket bushing when I could modify the bushing instead.
Attachment: Bushing_1.jpg (393.93 KB) 3 View(s)
Attachment: Bushing_2.jpg (377.51 KB) 3 View(s)
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
03-16-18 02:39 PM - Post#2727848
That looks to be the better idea.
66SS632
Loc: Langley BC
Reg: 02-09-13
03-16-18 09:42 PM - Post#2727896
For your situation it probably is.....
With my frame totally accessible I decided to enlarge the holes. I got a hold of a couple of hole saws one is 1 1/2" and the other is 1 7/16".
I machined down a chunk of aluminum to "tap fit" into the hole saw with the protruding dia same as the frame hole sizes which were 1.200" and 1.375".
After making the plug and everything I had all the holes drilled in 1/2 hour.
If you want to use this let me know.
Attachment: IMG_1522.JPG (2.12 MB) 5 View(s)
Rear most pass side hole drilled out to fit new bushing
Attachment: IMG_1525.JPG (1.87 MB) 5 View(s)
Drilled out to 1 7/16" for new size body mounts
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
03-19-18 12:31 PM - Post#2728173
Clean work. I'll hold off until we know how the replacement frame purchase unfolds. Thank you tho.
 Page 2 of 2 <12
Execution time: 0.463 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:32 PM
