Username Post: Universal Joint        (Topic#349636)
pauldian
Loc: seligman,arizona
Reg: 05-14-09
02-13-18 08:28 AM - Post#2724253
Looking to find the size of the zerk fitting on the 1956 driveshaft u- joint ?
Any help is greatly appreciated.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-13-18 11:56 AM - Post#2724274
    In response to pauldian
The 1956 U joint that was installed at the factory did not come with a grease fitting. The replacements sold by Chevrolet as well as other sorces did come with a fitting.
I don't remember the size measurement but it was the small straight thread in fitting. If it is a "modern replacement" it could be the pressed in type.
02-13-18 03:14 PM - Post#2724290
The thread size on the most common small fitting is 1/4"-28. If the replacement U-joint is an import part it might be metric instead.
pauldian
Reg: 05-14-09
02-14-18 05:56 AM - Post#2724346
Ray, I think you are correct in that they are
foreign made ?
I think I'll solve my problems and replace both
u-joints with the non grease able type.
Thank You Ray and to you Gene.......
Paul
Execution time: 0.188 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:19 PM
