Username Post: Running 2" drop spindals        (Topic#349633)
ta_lewis
Reg: 11-02-17
02-13-18 08:27 AM - Post#2724251
For everyone running 20" wheels up front. when adding 2" drop spindals to the stock front end 1. did it allow you to get the ride height you was looking for and 2. Did you have any alingment issues? Thanks for the help!
nicke
nicke
Loc: Spokane, Washington
Reg: 01-06-12
02-14-18 09:45 PM - Post#2724446
    In response to ta_lewis
I have a bit of input for you on this. I'll align with your numbers:
1) Did it give me the ride height I was looking for? Yes. The ride height you're looking for could be different though and is also dependent on the tire size you try to go with.
2) Dropped spindles have absolutely zero effect on the suspension geometry, so the chances of the dropped spindles being responsible for alignment problems is slim to none, aside from the actual spindle compatibility with the components they connect to and come in contact with.
Nick
My 65' Impala SS LS Swap
6.2L LS ,4L80E, 3.73 gears, disc brakes
Execution time: 0.193 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:13 PM
